Help with transfer case oil change
Old Jul 28, 2009 | 02:55 AM
EndlessRed's Avatar
i've been wanting to do the transfer case oil change, but after reading the instructions it seems there's more than the usual engine/transmission oil change process. specifically, there's a section in regards to bleeding the system, and using some sort of scan tool to focibly turn on the pump. is this really something i can do by myself, or should i take it to a dealer or third party that has said scan tool?
Old Jul 28, 2009 | 05:23 AM
Clipse3GT's Avatar
You do not need to bleed the system. Just drain and refill. There was a few threads about this if you would have searched.
Old Jul 28, 2009 | 11:51 AM
EndlessRed's Avatar
thanks. you're right - i just looked at the diy from russellm.
