Custom Evo 9 Clutch master cyl. Conversion=No more breaking!
Old Jul 30, 2009 | 05:21 AM
DG Motors's Avatar
Are you guys experiencing broken clutch master cyl? Does your clutch pedal just go to the floor? This happened to us previously 2x and we weren't going to stick around for the 3rd. After seeing a few of these threads popping up we decided to do something different. We had a metal evo 9 clutch master cyl. fabricated to fit the evo x clutch pedal assembly. We will be offering these as a kit both Installed and or made for you. Big thanks goes out to Tom at NRG-Tech for the Fab work and Slonez for the inspiration!
By doing this we believe it will be impossible to break the clutch master cyl now and there will also be no need for any type of clutch master rings to prevent the stock plastic cyl. from snapping in half under hard driving.
Initial impressions so far:
Great stiff pedal feel.(we have an exedy twin hd)
Can also be adjusted to stock pedal height with the Helm Joint.
Now onto some pics:
Pricing:
-$650.00 w/ core
-$850.00 w/out core
Includes:
Conversion, Evo 9 Clutch Master Cyl.
( Oem Evo 9 Clutch lines are on global back order, you must order a AMS S.S Evo 9 Clutch Line!)
$650.00 W/ Core for "Do it yourself"
$750.00 w/ Core to have us Install
$850.00 w/out Core
Some other minor fabrication and trimming of the clutch master tunnel is needed to make this fit.
NOTE: Here are all the part numbers you will need when calling to order the parts yourself. This Does Not Include The Part Number For The Master Cyl!
Rubber Hose- MR594664
Steel Tube- 2348A038
Bolt- MB5552841
Washers- MF660053
We will have 3 ready to go with a core exchange next Wednesday, September 30th! Call for availability!
Old Jul 30, 2009 | 06:44 AM
DarwinX's Avatar
Slightly higher pedal from stock.
This is great news...thank you!
One question though, are you saying the clutch pedal in your kit is even higher than the already too high stock clutch pedal?
Old Jul 30, 2009 | 06:47 AM
DG Motors's Avatar
It doesn't "grab" any higher. The pedal Itself lays at rest slightly higher than stock as compared to the brake/gas pedal. You get used to it rather quick.
It's nice being able to bang gears without having your clutch pedal slam the floor. So far so good!
Old Jul 30, 2009 | 06:52 AM
slonez's Avatar
Glad you managed to do the conversion.
Old Jul 30, 2009 | 06:56 AM
DG Motors's Avatar
You inspired us to tackle this project. Even though your pictures were for the jdm version, they still helped!
Thank You much!
Old Jul 30, 2009 | 06:58 AM
geezevox's Avatar
Guys, great work. When its time for a clutch, I will bring mine to you. Is there any way you could post some comparison pics to the stock assembly. Kind of a side by side view?
gizmotoy's Avatar
I would think this would be risking pedal or mechanical damage. Did you put in a higher bumper or something to prevent putting too much pressure on the pedal since it no longer contacts the floor?
Old Jul 30, 2009 | 07:10 AM
DG Motors's Avatar
Sure, I will snap a few pics for comparison!
Old Jul 30, 2009 | 07:11 AM
DG Motors's Avatar
You read that wrong. I was saying It's nice to bang gears without having the stock evo x clutch master snapping in half which results in no clutch pedal. The stock master breaks and your clutch drops to the floor.
This solution will never break a clutch master cyl.
Old Jul 30, 2009 | 08:18 AM
DVDee's Avatar
Great solution to a big problem.
Old Jul 30, 2009 | 08:53 AM
Guru's Avatar
What parts are needed? I want to do this. Other than the EVO 9 master cylinder assembly and a stainless line of course. Can I send you the pedal assembly to do it?
Old Jul 30, 2009 | 11:42 AM
DG Motors's Avatar
Evo 9 master cyl and evo 9 lines. That's all you will need.
The master cyl tunnel needs to be notched out a little bit in order to fit the new modified evo 9 master cyl clutch assembly through. The clutch pedal will also sit an inch higher than stock when laying at rest.
You can buy the parts and send me the assembly and we can have the fabrication done as you see above for $200. If you would like to go into more detail, feel free to call me, I am here to 5 p.m! Thanks!
Old Jul 30, 2009 | 01:11 PM
Clipse3GT's Avatar
Good to see some solutions out there. I wonder if anyone is planning to make a direct replacement for the X clutch cylinder.
What a terrible design by Mitsu, cheap bastards!
Maybe there will be a TSB.
Old Jul 30, 2009 | 01:43 PM
Evo J's Avatar
Congrats on the success! My nissan's master cylinder had to replaced 3 times, POS. I will definately be doing this mod on my evo in the near future
Old Jul 30, 2009 | 02:24 PM
DG Motors's Avatar
Tilton
makes a replacement but we wanted an oem clutch feel.
thanks..i still can't get over the fact they made it plastic..ridiculous junk.
