Need Help/Advice
Old Nov 24, 2009 | 09:24 AM
RaysEvoX's Avatar
Exclamation Need Help/Advice
This morning I started up my X but it would not go into gear. I turned it off let it sit for a little and tried again, same thing would not go in to gear. I let it run a little bit thinking maybe if it warmed up a little it would work. I was wrong. So I thought if I turned the car off, put it in gear than start it up it would work. I went to start it up and it had a hard time turning over. It finally turned over and it went into gear. This has happened 3-4 times now. Does anyone have any ideas what might be causing this to happen?
I have a Clutch Master FX300 Clutch and Lightweight Flywheel. I have tried launching it a couples times, but not for about a month.
Old Nov 24, 2009 | 03:48 PM
RaysEvoX's Avatar
Anyone with some type of input?
