To those with test pipe or HFC connected to stock catback
I will be installing my ultimate racing mini muffler test pipe to my stock catback....the kit did not come with any gaskets....however in the online FAQ, it says the following
"Our cat replacement pipes are designed to bolt on in place of the OEM catalytic converter. Simply put, if you can fit the OEM catalytic converter you will likely be able to fit ours."
So according to this, I should be able to put my mini muffler onto my stock catback with the stock gaskets no problem....right?
I just need to know if I can reuse my stock catback to catalytic converter gasket on my mini muffler no problems....
thanks for your time!
TypeR31
Feb 23, 2012 03:43 PM
Andrew@AMS
Automotosports - Illinois
10
Jul 22, 2010 08:44 PM
ReaperSevero
136
Aug 6, 2009 09:27 PM
