how to make close to 400rwhp w/ stk turbo?
Old Feb 6, 2010 | 10:43 PM
streetdreams552's Avatar
i currently have ems 4inch fmic
aem intake
tpb exhaust
i want to see if i can do this w/o cams i dont want to deal with lumpy idle
no tune yet can any of the cobb maps get me there?
or is there a generic map i could use as starter?
thanks
i am new to evo world check sig
Old Feb 6, 2010 | 10:44 PM
ive seen some people make 380 some claime 400 some make 310 whp numbers are irratice on the forums w basic bolt ons
Old Feb 7, 2010 | 12:07 AM
Frankiago's Avatar
On a Dynojet you will see about 380-390 on pump gas (93) with every bolt on and stage 1 cams on stock turbo post-tune.
Your list of mods will net you approximately 330-340 on pump gas (93) post-tune.
If you want to do a tune on a Dyno Dynamics, drop those numbers by probably 20+
400whp on stock turbo is possible with E85, but on 93 octane if you get to 400 whp that is a very high reading dyno.
You shouldn't be so concerned with the number unless it's considerably off (like you're running an FP Red with supporting bolt-ons on E85 with supporting fuel system and pulling 330whp)
Also, what sig?
Old Feb 7, 2010 | 12:33 AM
AWD Motorsports's Avatar
to make a legit 400 on stock turbo you need E85.. Pump gas in every case i have seen legit will get you 380-390..
Mike
Old Feb 7, 2010 | 03:10 AM
Toxin's Avatar
All bolt-ons + E85 // Meth injection.
Edit: I just noticed the title says Rwhp. Some further modifications on the car will be needed if you wish to make the power only on rear wheels
Old Feb 7, 2010 | 08:05 AM
ha ha im used to supr/rx7 talk nvr owned awd
so im guessing to accomplish my goal on pump i will need a biiger turbo? correct?
btw what is the diff btween the fp red and the garrett3076 bolt on?
Old Feb 7, 2010 | 08:49 AM
Toxin's Avatar
GT3076 is not a stock frame turbo while the FP Red is...
For the power and spool characteristics of the two, someone with more experience should chime in.
Old Feb 7, 2010 | 08:56 AM
MicMcKee's Avatar
Originally Posted by Frankiago
Also, what sig?
He means his previous rides, check under his name...
Old Feb 7, 2010 | 09:13 AM
abazaba410's Avatar
there is always the FP Green too....
Old Feb 7, 2010 | 09:24 AM
toostar-ish's Avatar
Also the Dom.2.
Old Feb 7, 2010 | 10:05 AM
xbevox's Avatar
The FP is a good choice , I've thought about it many times before .
Old Feb 7, 2010 | 10:43 AM
custm08's Avatar
what else is needed to fit an FP red besides the turbo itself? NOOB QUESTION I KNOW. I'm assuming bigger injectors and fuel rail plus a tune.
Old Feb 7, 2010 | 10:55 AM
abazaba410's Avatar
from my understanding just injectors.
Old Feb 7, 2010 | 11:11 AM
custm08's Avatar
Abazaba, you my only friend.
Old Feb 7, 2010 | 12:37 PM
Evo a Mula's Avatar
Best way to make 400 is e85 a good tune..came help a lot & a full bolt on car
