turbo fittings
Old May 17, 2010 | 10:52 AM
dadsgts's Avatar
turbo fittings
Hi i was wondering if anybody new what size an fittings the coolant and oil inout are. I was guessing the oil was 4an and the coolant was 6an but i want to comfirm before i order them. Im using a jerry rigged banjo fittings right now and want to clean the engine up a bit. Also do you think 10an for the oil return is large enough?
2008 gts evo charged 4b11
Old May 18, 2010 | 02:20 PM
UT_EvoX's Avatar
On the turbo? They're metric fittings if you're wanting to directly adapt something to cool the turbo.
-4 for oil feed (since it's a journal bearing turbo) and -10 is perfect for the drain.
Use -6 for both sides of the coolant lines.
That's pretty standard for any aftermarket or retro-fit turbo install. The fitting sizes on the turbo are (I believe) 12 mm x 1.25 for the oil feed, 14 mm x 1.5 for the 2 coolant holes, and a flange for the return. You can source any possible adapter you'd need to go from metric to AN from Summit, Jegs, ATP Turbo, etc.
Old May 18, 2010 | 04:40 PM
dadsgts's Avatar
fittings
Thank you very much for the help!!!!!
