is it the boost leak?
Old Jul 23, 2010 | 11:17 AM
hataeeun's Avatar
Hey guys,
it might be wrong forum... but
I have sort of problem on my boost..
a day after getting tuned, my evo was overboosting, over 30psi, and I set the boost as 50 duty cycle and 11 spring pressure to fix it, (was 60 duty cycle and 11 psi spring pressure before), and boost was 20psi only @ peak, so I reset it back as before(60, 11). and I felt like mine pulls weak, and boost was only 21 psi at peak. I though it has the boost leak. so
I just went to reset it as 65 cycle and 11 spring, and it works properly as before, 25.x at peak and holding 19~20.
However, I am still worried that why I had to increase 5 duty cycles to make it 25 psi as before............
any ideas?
Thanks in advance.
Old Jul 28, 2010 | 07:34 AM
macPSU's Avatar
Moved to engine/turbo section.
