What clutch wont break CMC?
Old Jul 31, 2010 | 04:33 PM
aronjaskim's Avatar
Besides stock what clutch can you run that wont break the plastic master cylinder?
Old Jul 31, 2010 | 07:30 PM
m3typer's Avatar
I hope the ACT HDSS can because I am installing mine next week. I almost sent it back to buy an OEM stock clutch because I plan on sticking with stock turbo. Restocking fees...lame.
Old Jul 31, 2010 | 08:11 PM
RaysEvoX's Avatar
I have the Exedy Stage 2 HD and it broke it after 6 months. What are your plans with the car? If you keep it close to stock than stick with the stock clutch and the CMC will be fine. If you want to upgrade the turbo , than you will need a stronger clutch, and than upgrade your CMC. I would upgrade it before it breaks.
Old Jul 31, 2010 | 11:09 PM
aronjaskim's Avatar
I will never have more than 350 wtq but I dont like how the stocker slips in first when launching.
Old Aug 1, 2010 | 08:06 AM
RaysEvoX's Avatar
Than I would upgrade to a better clutch and a better CMC. Better be safe than sorry.
Old Aug 1, 2010 | 08:12 AM
sailorcor's Avatar
What brand CMC would you recommend?
Old Aug 1, 2010 | 08:13 AM
hollywood_X's Avatar
The Specs or clutch master won't, they use a different fulcrum point on their pressure plates and put less stress on the system. Exedy makes pedal feel stiffer for the same reason womens jeans companies vanity size pants.
Old Aug 1, 2010 | 07:18 PM
aronjaskim's Avatar
The way I see it there is no good upgrade master cylinder. People are still having probs with the ssp unit. Plus the stock clutch can hold 350 wtq fine it just slips in first gear during launching which is annoying to me.
So specs and cm are ok, what else? Who else has upgraded their clutch but have not broke the master cyl yet?
Old Aug 1, 2010 | 07:28 PM
LagginTimes's Avatar
Not sure if you've seen this, but this is something that I am looking into doing some time in the future before I get a new clutch/turbo.
https://www.evolutionm.net/forums/ve...-breaking.html
I haven't read (or really searched for) any problems with this conversion.
RaysEvoX's Avatar
I have the SSP unit and love it. Its been installed over a month a not a single problem with it.
Old Aug 1, 2010 | 08:05 PM
Talon_66's Avatar
I believe Hollywood_X on the other forum has had great luck with the Spec clutches.
I think he has a Stage 3+
Old Aug 1, 2010 | 08:26 PM
JC7119's Avatar
Been running this setup for almost 2 months 0 problems with my carbonetic twin plate clutch.
Old Aug 2, 2010 | 05:52 AM
Kracka's Avatar
Did you remove the clutch restrictor pill in the slave cylinder? That will help a lot.
Old Aug 2, 2010 | 06:00 AM
Guru's Avatar
I have the DG motors Evo 9 MC conversion. Its a b*atch to install but it works great! I made my own custom stainless line.
Old Aug 2, 2010 | 07:14 AM
tsitalon1's Avatar
Custom clutch from Southbend.
I've been running it for 18k miles or so with no issues. SB stated it can handle 490 ft/lbs. (currently I'm only pushing about 305 ft/lbs)
See my sig for description, contact Andy from Southbend for more info...ball park price is 650 or so.
