The FP Black for the X is here! Mellon Tuning
Old Aug 17, 2010 | 01:47 PM
Mellon Racing's Avatar
The FP BLACK™ for the Mitsubishi Lancer Evolution X is here. This is the most fully evolved stock appearing variant we offer. It features an 82mm HTA™ compressor wheel with a flow rate of 68lb/min. The turbine side features a large 67mm turbine wheel.
The turbo comes standard with an 18psi wastegate actuator and the FP Evo X High Flow Oil Supply Line. You may select a lower pressure actuator if needed, but the unit is intended to operate above 18psi of boost pressure. This turbocharger will produce 500-600whp results readily on well prepared engines.
So who's going to try this badboy first?
http://www.mellontuning.com/index.ph...roducts_id=615
Old Aug 17, 2010 | 01:58 PM
chkmgnt59's Avatar
little late to the party......
unless you can give us final dyno numbers :-)
Old Aug 17, 2010 | 02:02 PM
murlo26's Avatar
I was going to try it first, who knows maybe in two weeks I will still be the first. This has been a doorstop for me for a few weeks now
Old Aug 17, 2010 | 02:08 PM
that's a fancy door stop hehe
Old Aug 17, 2010 | 02:09 PM
murlo26's Avatar
Your telling me 11th of Sept I will have track times though
Old Aug 17, 2010 | 02:12 PM
definitely keep us posted with the results, are you doing e85 or 93?
Old Aug 17, 2010 | 02:14 PM
murlo26's Avatar
E85 and hopefully if Tephra helps me out in time (we are in process, well lets be honest just him, lol, i will just test it and dontated the $100 4bar MAP sensor) 36-38psi with PSI based boost control
Here is my build thread....
https://www.evolutionm.net/forums/ev...lack-time.html
Old Aug 17, 2010 | 02:15 PM
haha that's going to be ridiculous with this turbo
Old Aug 17, 2010 | 02:37 PM
murlo26's Avatar
Should be hopefully /pray for 600whp+
Old Aug 18, 2010 | 07:23 AM
Kracka's Avatar
http://www.youtube.com/watch?v=t6bAZmEEIb0
Old Aug 18, 2010 | 07:25 AM
murlo26's Avatar
That is low Kracka...how does that have anything to do with my build...if anything you are making fun of DB...sick of Mitsustyle nonsense lately.
Old Aug 18, 2010 | 08:02 AM
Kracka's Avatar
Dude, it's a joke, lighten up! You take the internet too seriously
Old Aug 18, 2010 | 01:55 PM
HybridKOOP's Avatar
That's an 8/9 Black
Old Aug 18, 2010 | 01:59 PM
CA$H's Avatar
Originally Posted by Kracka
Best vid ever! LOL
Old Aug 18, 2010 | 02:22 PM
EVO X 6950's Avatar
priceless
