Exedy Stage 2 Clutch Install - what a nightmare
Old Aug 24, 2010 | 02:05 PM
MonacoGP's Avatar
Eventually I'll make a post about the whole process but for now I'm stuck on the TOB. It's a new TOB/wave spring/snap ring that came with the clutch.
The snap ring keeps sliding down the TOB shaft when trying to engage the wave spring for the first time. The ring is supposed to slip unger the wave spring collar then not let the collar pass back by therefore engaging the TOB.
Any ideas?
I'm really concerned that this thing will pop off in the other direction if/when I finally get it installed.
I've been trying to get the forum vendor I purchased it from and Exedy tech support to give me a call but apparantly they are all on vacation.
Thanks
Little advice for you guys contemplating taking on this job. Pay somebody else. It's a big PITA much harder than any other clutch I've ever done.
Old Aug 24, 2010 | 02:08 PM
Guru's Avatar
So the snap ring is not engaging when you push lever back? I had that problem had to pull trans back off and make sure the snap ring on the cover was correctly installed. Sometimes you can bump it with the input shaft as you're putting it in. Put trans back in and snapped right in place first try.
Old Aug 24, 2010 | 02:14 PM
MonacoGP's Avatar
The snap ring pops out of it's bead and ends up pushed back by the wave spring collar to the face fo the TOB. I've made sure by looking through the access port everything is properly aligned before trying the lever. Several attempts so far. It's killing me.
Old Aug 24, 2010 | 02:20 PM
thekhmer's Avatar
should've got an act clutch instead they are always on the line when i call lols..im probably no help but makes sure twice that everything is aligned right..if it isnt it can cause the ring to pop off and i would not install it until i was sure everything is perfect..
Old Aug 24, 2010 | 02:21 PM
HybridKOOP's Avatar
I'm dead smack in the middle of a clutch install on my X... and you're right, what a pain in the ***... NOT fun. Hopefully I don't run into an issue with this wave spring crap. I destroyed the stocker on the way out... became disassembled into like 6 individual pieces.
Lou
Old Aug 24, 2010 | 02:32 PM
MonacoGP's Avatar
Lou
Sounds like you didn't get the fork to disengage. Ran into that problem too. Had to do the 6 bolts on the flywheel to get it apart. Tore that wave spring up trying to pry/pop the TOB before that. Good luck.
Old Aug 25, 2010 | 04:31 AM
MAS2377TECH's Avatar
From: Philly, Germany, Japan, UK...South Dakota (Da Sticks).......
Man, I was just looking at getting a new clutch too....looks like I'll be looking for a good mechanic for da hook up!!!
Old Aug 25, 2010 | 08:54 AM
NotAnEvoOwner's Avatar
Clutch is the biggest PITA i have ever dealt with. Hence why im nice to mine.
Old Aug 25, 2010 | 11:21 AM
IrvineXGSR's Avatar
i need a new clutch too and i thought it'd be a good learning experience to do my own ... now i'm debating it. hahahahh. good luck.
Old Aug 25, 2010 | 11:35 AM
If you think its gonna take you 2 days, give yourself 4.
Old Aug 25, 2010 | 01:14 PM
MonacoGP's Avatar
Amen. This is not a normal tuner car clutch that you can drop on your chest and wheel out on your crawler. The thing weighs nearly as much as most engines. If you aren't sure you can do it, don't even try. Best bet would be to asist on one first even if you have done a bunch of other clutches in the past. The thing is really packed in there and a few of the bolts/nuts are nearly impossible to reach without experience. Second time through would be much easier but still not worth it. Never again.
Old Aug 25, 2010 | 01:21 PM
aronjaskim's Avatar
I have a question, how much more work would it be to just pull the engine and replace the clutch with engine out? It sounds like you have to disconnect almost everything any way.
Old Aug 25, 2010 | 01:25 PM
MonacoGP's Avatar
Really wouldn't be much more work. We ended up taking the engine off the mounts to get room anyway.
Old Aug 25, 2010 | 02:30 PM
Same here when we did my friends clutch. Literally if you have little to no experience working on cars, dont even try. You need to have done a least a couple clutches.
And as stated before, some bolts will take you 5-10 min to get to you first time because they are buried between the transfer case and the trans. To drop the motor is would just be a matter of the wiring harness.
Old Aug 25, 2010 | 07:59 PM
EVOX_Ryan's Avatar
Thanks for posting this as it confirms a shop will be doing mine.
The emotional trauma would not be worth it!
