Why does our torque drop so much after the turbo spools?
i've noticed that evo's running stock turbos have good torque to about 4-4.5k, however the torque starts to drop once the turbo spools...and the HP picks up.
is that because of the restrictive stock turbo?
It doesn't matter what size turbo you have...if you are pushing the turbo more down low than it can possible support up top as the engine is able to ingest more air you will get this drop off.
Basically the problem is we are all going for super fast spool and high torque spikes but the turbos cannot maintain them. To get a flat curve you need to get pretty much a 35r and run like 28psi flat and you should have a nice flat torque curve.
I could have a flat torque curve on mine if I ran really low boost but wheres the fun in that?
Notice how when boost starts tanking, so does your torque....
