My FPblack vs. FPred Comparison
Here is my shops overlay of my FPred setup and my FPblack setup.
Obviously the FPblack has different cams and head work...but a decent comparison as its same car (not really same motor, lol) but most importantly the same dyno!
http://dbptuning.com/dyno/graph_data...ata_type=boost
The HP/boost one is goofed up i think, but just check them out individually I guess.
I love the FPblack.
I love the FPblack.
Obviously I don't have to.
But what kind of answer it is?
If you want to compare spool characteristics for those turbos I have to ask you again: what is the point to compare stock vs cams & headwork?
Because what you have tested has nothing to do with pure turbo comparison.
Maybe I am missing something here but IMHO to compare two turbos you shall do it on same car, same motor, best if it same day (to get very precise results) or just with similar weather conditions.
Yea I would've loved to wasted thousands of dollars swapping cams and turbos on a stock motor just to please you.
I was simply showing my two setups and the fact that the black spools pretty dang good.
Please me? Give me a break.
To justify the title of the post, maybe.
OK, you will not understand.
Fully agree - comparing two setups, not the turbos.
EOT.
All the best.
EOT.
All the best.
My head work isn't mild really, its fully built. I got +1mm oversized valves, dual springs/retainers, the new cams, and the head is ported out.
I would love to see a comparison of the Red vs. Black at the same psi level. Your graph shows 80 extra HP with the Black, but it's also running an extra 6psi. TQ is only 25 higher too which is odd. At the same PSI level it seems like the Black would barely make more HP and possibly even less TQ than the Red.
So if you look the black is a few hundred rpm's laggier when running similar boost levels and torque is lower, but that is because spool is slower. Torque on these cars are directly related to spool, the faster you spool the more torque (peak) you make since its earlier in the RPM's.
However, if you look the black's torque curve is way flatter.
Anarchy99
Jan 18, 2012 08:41 AM
