Boomba Intake Manifold Gasket Work?
Old Nov 6, 2010 | 07:34 AM
elusiveGSR's Avatar
Anyone have personal experience with this thick gasket? Does it really lower the temp? Install difficult?
Old Nov 6, 2010 | 08:09 PM
DannyK24's Avatar
Simple install. Took about 2.5hrs or a little less. Intake manifold still gets hot but not as much as before.
Old Nov 8, 2010 | 07:16 AM
Hiboost's Avatar
This gasket seems to help but I went a step further and also bypassed the coolant lines leading through the TB. Now the intake manifold seems to hover around the same temps as the surrounding underhood air which is cooler than the ~200* F head temp. When it's 90*F + outside the underhood temps are still pretty hot so just going by feel it's hard to compare easily. However when you compare it on a 40* F day and go for a drive, if the underhood temps stay reasonable you can grab the intake manifold and it will be cold while the head/valve cover is very hot. Datalogging wise I noticed about a 10-20* F drop on the intake manifold temp sensor while driving but that is somewhat fishy for accuracy since it heats up quickly due to heat soak in the engine bay. Probably if there was some way to vent fresh air over the intake manifold it would be closer to the outside air temps all the time when driving which is about as good as you can expect.
EVO 4 life
Jun 29, 2016 08:28 PM
QwikEVO
Aug 16, 2015 11:25 AM
Audi2Evo
10
May 14, 2010 10:34 AM
kozmic27
Jun 28, 2009 11:38 PM
