Clutch Disk
Old Nov 14, 2010 | 07:54 PM
twinturbogreg's Avatar
Clutch Disk
Can anyone confirm that we run the same clutch disk as the Evo 7, 8, and 9?
Old Nov 15, 2010 | 09:39 AM
dek0026's Avatar
i don't know how you want me to confirm but yes you can use the same clutch as the 8's and 9's. the TOB is different though.
Old Nov 15, 2010 | 03:07 PM
Mike W's Avatar
Same clutch disc yes.
But since the release bearing is different (mentioned above), the clutch pressure plate is also different. Well... at least the whole mouse trap piece where the release bearing clips into is different. So technically the pressure plate is mostly the same, an important part of it is different.
Mike W
