Which is a better street flywheel? 10/13
Old Jan 5, 2011 | 10:32 AM
gman88's Avatar
I am trying to decide which flywheel to get. The act 13.1 lb or the act 10 lb. Its going to be a "daily driver" of sorts, I have a motorcycle I drive alot in the warm months. But which would be better for street use. the 13 or 10 lb flywheel? The 13 lb is 280 shipped, And the 10 is only $13 more at 293 shipped. Based on price the 10 lb seems like the better bang for the buck. Less mass/ faster revs and acceleration. But my common sense is telling my the 13lb would be better for street use and 10 lb for more of a racing type car. Need Opinions and personal experiances with it
Old Jan 5, 2011 | 02:59 PM
LapDance's Avatar
go with the prolite =) I've been told by a few tuners that it should be fine for daily driving
Old Jan 6, 2011 | 01:44 AM
anasmak11's Avatar
I read that the exedy twin setup is lighter that the prolite with a clutch setup. is that true?
Old Jan 6, 2011 | 08:36 AM
LapDance's Avatar
i just got my exedy twin in, Ill try to measure the weight sometime soon.
Old Jan 6, 2011 | 09:06 AM
gman88's Avatar
I would appreciate others input before I make a final choice and order one or the other..
Old Jan 6, 2011 | 09:29 AM
armysoldier1073's Avatar
I have the streetlite. i like it now that i have gotten used to the clutch. but if i would do it again i would save $300 and have the stock resurfaced. if you get the stock resurfaced it brings it down to the weight of the streetlite. there is only a 7oz to difference to begin with anyway. I also run the ACT sprung 6 puck.
Old Jan 6, 2011 | 09:38 AM
UT_EvoX's Avatar
It may not be physically lighter, but it is definitely smaller in diameter and therefore its rotational inertia is lower (which makes it easier for the engine to rotate it, the same way a lighter flywheel would be easier to rotate than stock).
Old Jan 6, 2011 | 09:44 AM
ChrisCarey's Avatar
Don't forget to check ours out! It's 9 lbs and just $259.99 shipped, plus you get an MAP gift card valued at $28.60 if you use discount code 2011rebate during checkout
Old Jan 6, 2011 | 09:55 AM
gman88's Avatar
hmmm Way to make my choice even harder then it already is. I acutally just bought a forge rs dv from you guys today
Old Jan 6, 2011 | 05:23 PM
gman88's Avatar
After much debating, I just ordered your flywheel, Why not try something different and break from the normal big weights like act/clutchmasters/exedy etc
Old Jan 7, 2011 | 01:26 AM
anasmak11's Avatar
how does it compare to the prolite? is it better?
Old Jan 7, 2011 | 06:47 AM
Kracka's Avatar
-lighter in weight (pros and cons)
-aluminum (should dissipate heat more effectively)
-replaceable friction ring (potentially lower cost during future clutch jobs)
Old Jan 7, 2011 | 08:08 AM
ChrisCarey's Avatar
Awesome thank you
Old Jan 7, 2011 | 08:10 AM
ChrisCarey's Avatar
Kracka hit the nail on the head, the only thing he forgot was the significantly lower price of our flywheel
Old Jan 7, 2011 | 01:58 PM
murlo26's Avatar
Light flywheels are great and all for street driving and road courses.
However, heavier flywheels are better for drag racing as you need that extra material to take the abuse from launching.
