ATP GT3071R turbo issue!
Old Jan 29, 2011 | 12:02 PM
ramievo7's Avatar
I just finished installing an ATP gt3071r turbo kit for my friend's evox gsr! it was easy install and no issues ,started the car and drove it for 15 min and all was good till i let the car idling for more than 3 min the car start smoking white /blue heavily with burned oil smell inspected everything ! when i drive the car the smoke goes away right away even flooring it NO SMOKE @ all !!!!! it smokes @ idle only !
after taking off the turbo i noticed oil all around the turbine blades !! it seems seal is leaking !!! how come new turbo start leaking first day!!!
hope to hear from ATP guys !!!
thanks
Old Jan 29, 2011 | 12:27 PM
Huge's Avatar
Did you pre oil the turbo bearings before starting the car and going for a drive? Ive always been told to do so, but I don't know if it really makes a difference.
Old Jan 29, 2011 | 12:31 PM
ramievo7's Avatar
yes mate i did! that really sucks to have leaking 2000$ turbo !!
Old Jan 29, 2011 | 12:34 PM
06MREvo's Avatar
This thread will probably get closed...you need to contact ATP directly about this...
Old Jan 29, 2011 | 12:35 PM
ramievo7's Avatar
I did emailed atp and still waiting their feed back!
Old Jan 29, 2011 | 12:37 PM
06MREvo's Avatar
Call them too...
Old Jan 29, 2011 | 01:03 PM
akauf's Avatar
U have the right restrictor on it?
Old Jan 29, 2011 | 03:32 PM
spdracerut's Avatar
If it's the Garrett bolt-on, then it comes with a restrictor. Is there any shaft play or anything? I would lean towards it being an oil drain line problem. That line can be a royal pain to line up correctly.
Old Jan 29, 2011 | 11:22 PM
ramievo7's Avatar
I have used the retrictor that came with the kit ,and for the drain line it fits only the right way ! as shaft play it has normal shaft play ,nothing touching the housing ! the strange thing is it does leak/smoke only if i leave the car idling for few mins!!!!
Old Jan 30, 2011 | 01:28 AM
spdracerut's Avatar
That is weird..... A couple other things to check: PCV valve, compression and leakdown test. Excessive blowby can cause high crank case pressure and cause oil to leak out the turbo. A leakdown test should find this.
Old Jan 30, 2011 | 02:39 AM
ramievo7's Avatar
Thanks buddy! i did that too ! the only thing i noticed is this car has very low vacum
@ idle!! i know its coz of the cams but this is very low vac for cossi's cams!
Old Jan 30, 2011 | 10:34 AM
spdracerut's Avatar
With the vacuum so low at idle, it might be building up excessive crank case pressure at idle, and that would cause smoking.
How does the car run? I'm wondering if the cam timing is off by a gear tooth or two which is causing the low vacuum. Or maybe just bad piston rings? I don't know if bad rings would cause low vacuum though, but just blowby.
Old Jan 30, 2011 | 11:37 AM
ramievo7's Avatar
thanks i'll check the timing marks and see!
Today i was checking the turbo it self i tried to blow some air through the oil line and noticed the ait moves heavy inside the turbo it self !!! like the catrige blocked or somthing !? i'm lost here
EV0lvedX
Aug 11, 2016 03:20 AM
hutch959
14
Apr 6, 2016 12:42 AM
fabiano
Mar 13, 2016 01:01 PM
aronmatic
Apr 13, 2011 10:42 AM
mobounce
15
Feb 1, 2005 06:21 AM
