Couple issues im having with my mr
Old May 3, 2011 | 01:32 PM
Hakmeister's Avatar
lately ive been having this issue where, randomly on startup my rpm,s jump for about 5-10 seconds from 500 to 1k back to 500 then back to 1k. then the car just shuts down. then when i restart it all is well. o.0. it hasn't happened a lot in the past, but Ive been noticing that its been doing it more. also, today, when i turned my car off and came back like 5 mins later to start the car i put the gear into reverse and my car just sat there with the R blinking. wouldnt go back at all. had to put it back into park and then back into Reverse and then it moved. i hope the tranny isnt going out on me . anyone experience this? im going to try and get my CEL pulled today or tommorow
Old May 3, 2011 | 01:37 PM
Kahrs's Avatar
Mods? Km's? any track time? more info plz
Old May 3, 2011 | 01:52 PM
Hakmeister's Avatar
Mods : AEM intake, Greddy turboback exhaust, cobb ap tuned.
40k miles
No track time, Minimal hard driving
Old May 3, 2011 | 02:08 PM
Evod350z's Avatar
the reverse light blinking usually happens during reslly cold weather. Either let it warm up a little then go to reverse or do what you jus did.
Old May 3, 2011 | 03:55 PM
OG Mogie's Avatar
This problem you speak of has been with my car since it rolled off the dealership lot. Dealer could not find anything wrong when I brought it in and its been like this for 3 years now. Only happens once in a while and most of the time it doesnt shut down, just rough idles for a few seconds. Wouldnt really worry about it. The car is prolly just moodie.
Old May 3, 2011 | 10:52 PM
lancerarmstrong's Avatar
If you read the manual the reverse light blinking means that it failed at engaging itself into reverse. It says to put it back into Park for 5 or so seconds, then back into reverse. It happens semi-frequently on mine but I don't consider it a big deal. Just make sure to tell service people that if it happens then put it back into park for a little bit then try again
Old May 4, 2011 | 01:18 PM
redmachine's Avatar
ive had that too...
Old May 4, 2011 | 03:36 PM
EVO-J's Avatar
What year is your EVO X? I've had a similar issue like this before, however, I brought it back to the dealership to get the ECU reflashed and updated. It helped, but ever since the trip to the dealership, its only happened once or twice...
Btw, I have an 09 MR...
Old May 5, 2011 | 06:03 AM
Hakmeister's Avatar
Its an 08. I haven't updated he cobb ap map ever since I got it because my dongle broke. Shoukdi investin that. I wanna say its been over a year
Old May 6, 2011 | 09:18 PM
flipflop's Avatar
My 08 MR had the 'idle" issue too. I went to the dealership and got my ecu reflashed but I still had idle problem afterwards. I finally got a dyno tune after I got a drop in filter and a CBE. My tuner stated that he ran into a lot of these "idle" issues with the 08 MRs. It had to do with running too rich out of the factory, so he changed the a/f r to 10.5 to "lean" it out a little bit. That resolved the issue. Maybe that's what running into. IDK though since I'm not a tunner. I would suggest to talk to a local tuner in your area. GL
Old May 7, 2011 | 08:37 PM
KSIceman's Avatar
I've also had issues with idles, and my car is 100% stock. There's a thread on here about fixing some kind of vacuum line that might fix it. I don't remember where it is, some searching my find you what you're looking for.
Old May 8, 2011 | 12:23 AM
Madrican's Avatar
I had this problem since the day I brought my car. I took my car to the dealer about 5 times because of this with no solution to the problem.
I have recently upgraded my turbo with supporting mods and since then I haven't received this problem yet but then again I only had this new upgrades for about 2 months now.
