Damaged engine on first track day, advice needed
Bent crank haha, it could snap or crank but they don't bend. The journals could be really messed up though.
As long as there is no hole there he should be able to reuse the block portion.
I recently went to Thunderhill in NorCal, and after just 8 miles on the track, I lost power and heard a sputtering sound from the engine bay. Thinking I had a boost leak, I stopped in the paddock but the car was running fine. No CEL, coolant not overheating (note: I don't have an oil temp gauge). I took it back on the track, and almost immediately I got the same power loss but this time when I stopped in the paddock, the idle was rough. It sounded like the car was running on 3 cylinders.
My car is mildly modded - I have a MBC, drop-in air filter, torque tables upped in the ECU by +5%, and a Z-Chip which I used with a wideband to smooth out my HP/torque curves. My boost peaks at 25psi and tapers to 20 by redline. My big mistake: it was a hot day and I was running 91. I normally have a zero knock count but wasn't logging that day.
I called around a few places but nowhere knew about Evo engines, so I had it towed to a Mitsu dealership. They took off the head and found the following:
- damaged exhaust valve
- warped head
- scored cylinder
- damage to short block (unclear what exactly, they are still looking)
- unclear about piston damage
They quoted me $8300 to fix all that, assuming they can machine the head. I think the quote is ridiculous, but haven't yet looked at the parts/labor breakdown.
I know Speedelement is in the Bay Area, so that's an option. Any other suggestions? While I've got the engine apart, I should probably consider replacing some parts. Is there a thread somewhere with suggestions? I wasn't able to find anything. My goals are currently to become a better driver on road courses but later I will be after some more power. No more than 400whp.
- warped head
- scored cylinder
i am not sure that is a right combo from the begin with. MBC for the X with stock ecu and others is a step back, the Z-chip i could never figure it out ,
be smart and drop the MBC use ecu controlled boost and use a proper tuner, you will be much happier and so as your car.
Rob
The MBC and Z-chip have been on the car for a long time. I took a lot of advice from evom when I installed the parts over two years ago and I've had no problems with them on the road, but obviously the track is a different environment. After the rebuild I'll be letting my shop/tuner prepare the car.
Sorry to hear about your car. As everyone else says, go to GST. Razorlab might be able to help you out since he is kind of associated with GST but I would try to call them directly. If you can't get a hold of them there, go to the evoempire forum and PM "GST Motorsports".
That ZChip might have survived in a street environment, but for road racing it needs to be spot on or the engine is going to let go. Excessive timing for the type of fuel being used was likely the cause. The MBC vs ecu boost control wouldn't have been a factor if each setup were properly dialed in for the boost levels that were safe.
I'm currently talking with a couple of different shops based on recommendations here and will come out of this with a full engine rebuild with better internals and track-safe cooling and power mods.
Same problem here - seriously bent intake valves. Timing chain skipped at start-up
Took it to the dealer, since I figured it would be the easiest place to go if it were a simple issue.... nope. They quoted me $14,000 after tax to replace the motor.
They told me the motor failed compression test. When I asked them what exactly was damaged and if anything was salvageable the response was "no, we didn't look, but in our experience, the result is normally a new engine". Like F*Yourself.
So I told them to not touch the car anymore and I'd have a flat-bed come to pick it up... decided to finish what they started and took the head off at home.
I found:
- 8 bent intake valves
- scored cylinder
- slight damage to piston
Sorry, didn't mean to hijack lol.
What did you end up doing?? I am in the process of deciding what my most economical options are until I bring the car into a local shop.
Took it to the dealer, since I figured it would be the easiest place to go if it were a simple issue.... nope. They quoted me $14,000 after tax to replace the motor.They told me the motor failed compression test. When I asked them what exactly was damaged and if anything was salvageable the response was "no, we didn't look, but in our experience, the result is normally a new engine". Like F*Yourself.
I found:
- scored cylinder
I had a similar problem few years back and it was a boost leak but only leaked while boosting under load on track. In the paddock it was fine. Usually beyond 15lbs it would leak.
check your couplers. they may look tight but are not
I found:
- scored cylinder
I found:
- scored cylinder
Just a quick update: in the end I had GST rebuild my motor and install a Koyo radiator and AMS SST cooler. Overall I'm very happy with the car. I'm still on a stock tune with no mods but will be getting the car tuned in the new year. Primarily I'm after a very reliable track car and don't really need much more power.
CrazedRacing
Northeast Region
27
Mar 20, 2011 12:26 PM
