Exhaust Fitment Question
Hi all,
Noob question here, but I recently purchased the Cobb Cat-Back exhaust and tried to install it only to find that I had completely forgotten about the different diameter piping.
Is this the right type of adapter to get to make sure it fits correctly?
http://www.fredbeansparts.com/index....adaptor-1.html
The stock cat is a flat type of flange and the mid pipe is also flat, so I'm wondering if this will or won't work.
Thanks in Advance!
Thanks in Advance!
Thanks for the info! I also called Cobb to confirm fitment. They said it should bolt right up and to actually pry or remove the heat shield.
I'm now debating between unbolting the sides of the heat shield and prying it back with pliers and flat head or just cutting off the excess with a dremel.
nine4surfah
Aug 15, 2003 03:05 PM
