Notchy/Grinding into 2nd and 3rd
Old Sep 5, 2011 | 12:45 PM
alexandertg4's Avatar
Any one experience this? I am wondering if this is normal for a new evo or not. I have 400 miles on the clock and sometimes I get a notchy almost grinding sound when I try to shift into those gears. I have never experienced this before on a manual vehicle and this is with the clutch pedal pressed all the way down.
Old Sep 5, 2011 | 05:27 PM
Answer_1's Avatar
"normal" behavior... search, you'll find lots of info about this.
Old Sep 6, 2011 | 07:20 AM
VSGTS14's Avatar
mine also does it, very slight, not all the time. i just had the tranny rebuilt also with only 15k on the clock.
Old Sep 6, 2011 | 07:36 AM
oftheheavens's Avatar
shift cage bushing, new/better tranny fluid, works short throw, flossy heavy weight knob. problem solved.
Old Sep 6, 2011 | 02:00 PM
Answer_1's Avatar
I personally have Redline MT-85 fluid, TWM shifter with base bushings, and It's still notchy...
Old Sep 12, 2011 | 06:40 PM
SeanM505's Avatar
i have 3300 miles on my evo and have been experiencing ever since i got it, its very annoying.
Old Sep 12, 2011 | 09:28 PM
dboz's Avatar
A heavy extended shift knob will eliminate 98% of the grind.
