Cams.. options?
Old Jan 10, 2012 | 06:26 PM
T6's Avatar
T6
Cams.. options?
First off, I want to apologize as the "search" function never works on me as I most likely suck *** at finding anything via it.
Second off, I am not all that much of a gear head to understand the differences between cams...
Anyhow...
A brief intro to my '10 mr touring... She is my DD and I am planing on hitting 400s on 91.
I was initially going with Tomei's 270/270 procams however due to recent changes with Tomei, I wont be able to get my procams in time before I am getting the rest of my stuff installed (ef2, exhaust/intake manifold, heat shield for sensor, afpr fuel kit -all MAP products,my mil.spec TB and GSC springs). I was told that I wont get my Tomei cams till Feb and I am getting those parts listed above installed in January 20th.
So, I am in the market for new cams and what would you guys suggest? I wont be going the Kelford B route due to the failures I have heard as well as from a friend. I have the GSC springs so I need a camshaft to go well with those springs and be perfect for DD.
I appreciate the input!
Old Jan 10, 2012 | 07:12 PM
2003evo8's Avatar
Ams tmp
Old Jan 11, 2012 | 05:54 AM
Kracka's Avatar
Kelford -B or GSC S2. The Kelford failures were on the IX intake cams using an old core design (Cosworth and GSC also suffered from this). The S2's will be the more aggressive of the two, you could also consider the S1's which will be slightly milder than the -B's.
Old Jan 11, 2012 | 06:02 AM
escodotcarter's Avatar
on a side note, instead of using the sites search function just type whatever you want into google and then throw either an "evo ix" or "evo x" at the end of it and more then likely this site will be top of the results. MUCH MUCH better way to search this place.
Old Jan 11, 2012 | 06:32 AM
01CBR929's Avatar
Ditto what kracka said, if I could choose now it would probably be gsc s2 cams. There is a good cam review done by ams floating around too.
Old Jan 11, 2012 | 06:49 AM
scheides's Avatar
EvoM Moderator
I wanted GSC S2's when I was building my engine but they were unavailable. I went with the Kelford 214-b's and have had great luck with them; they make fantastic power and are very very mild-mannered on the street. Either are a great choice IMHO.
Old Jan 11, 2012 | 08:24 AM
ChrisCarey's Avatar
We've got 4 sets of GSC S2's in stock my friend
Old Jan 11, 2012 | 10:28 AM
gsup85's Avatar
GSC S1 is also nice too.
Old Jan 11, 2012 | 12:07 PM
murlo26's Avatar
x2, I have the GSC s2's and I have been in Scheides' car, both are great cams.
Problem solved OP, Place order now
T6's Avatar
T6
I did decide to go with GSC S2's. I have the valve springs from GSC anyways so it only makes sense.
lol, Adam already did my switch from tomei's to those
Old Jan 11, 2012 | 12:12 PM
01CBR929's Avatar
Good choice. I wish I had some.
Old Jan 11, 2012 | 03:37 PM
T6's Avatar
T6
MAP has 3 more!!
ps: Thanks a lot for the notification Chris
That right there needs to be my signature if mine wasnt big enough already I would add it haha. +100
Old Jan 11, 2012 | 03:47 PM
AllOutEvo9's Avatar
Do yall have some in stock for a 9 ?
Old Jan 11, 2012 | 03:57 PM
ChrisCarey's Avatar
Only 7 sets for the Evo 9 in stock PM maperformance Adam will hook you up!
