BeaterX gets an EF4, thanks MAP!
Just kinda what I mentioned above. I've posted some write-ups and diagrams on how it's setup in the ecuflash section, PM me if you cannot find them. It's a nice mix of the ease of adjustability of a MBC but still help eliminate taper that these stock-frame turbos enduce.
LOL this was not on a dyno, I just was doing pulls on my way home from work
I consistently rev the car to a hair over 8000 but looks like now I will get a little more by revving it higher, who knows!That is both manly and funny at the same time. I love it.
BBX you mean!
Close. I was running 33psi at ~7500rpm during an initial pull and AFRs were at 12.5. Lowered boost to 31 up top and it's now in the high 11's. This sucks because it's on E70. I'm going to need to do something once E85 comes back in a few months. Gah the cycle continues!
I will post this in the walbro 400 thread too.
It uses both the MAF and speed density. Also our MAF is a hotwire MAF, so if he really needed to he could just go to a custom 4" intake (or really just 4" maf housing) and it would give him a ton more room.
I'll prolly just rock the 3.5" and push it to the absolute limit, I'm guessing I won't quite flatline it, no biggie.
Ricer math kinda works out...I made 380whp at DB Performance on my stock MAF housing, 3.5" intake cross-sectional area is 1.39 times bigger, 1.39*380=529whp, or about 610whp on a dynojet.
IDK if I'm ready for that level of commitment
I'll prolly just rock the 3.5" and push it to the absolute limit, I'm guessing I won't quite flatline it, no biggie.Yea I don't think a 4" is necessary for stock frame either, you should be alright. Your rice math seems about right honestly. I figured about the same, I thought 610-620whp dynojet was about where the EF4 will run out. I made 495 on 27psi at DB so I think 530 on 32psi or so is possible.
