Looking to upgrade from FP RED
Old Feb 17, 2012 | 11:04 AM
NotAnEvoOwner's Avatar
Currently have a FP Red on the car. Looking for more power and going to build the motor. Should i go to the FP Black or the EF3/EF4? Looking to keep it stock frame.
Old Feb 17, 2012 | 11:05 AM
soon2bEVOIX's Avatar
Why are you not happy with the Red?
Old Feb 17, 2012 | 11:09 AM
I am. But here in CA theres only so much you can do with 91. So if i build the motor id like to be able to be in the mid to high 400's.
Old Feb 17, 2012 | 11:21 AM
NewEvolutionIX's Avatar
Doesnt they have E85 out there?
Old Feb 17, 2012 | 11:35 AM
SilverShadow03's Avatar
^CA does have E85. Depending on where you live, it may not be easily accessible or worth the hassle to drive and fill up somewhere remote or out of the way.
Old Feb 17, 2012 | 11:46 AM
All the E85 stations are 45 miles away minimum. I also don't want to be tied down to run only
E85
Old Feb 17, 2012 | 12:19 PM
ChrisCarey's Avatar
EF3 wouldn't be a significant change, EF4 would be though
Old Feb 17, 2012 | 12:24 PM
Sounds good. Been eyeing the EF4 turbos for a while now.
Old Feb 18, 2012 | 07:03 AM
Clipse3GT's Avatar
Stock frame about the largest would be FP Black, EF4, GTX 3076R?
Old Feb 18, 2012 | 02:30 PM
spdracerut's Avatar
ATP turbo also makes GTX3576 and GT3582 versions of the Garrett bolt-on. For maximum pump gas numbers, need to step up the of the GT35 size turbos. A compromise in spoolup and power would be the GTX3576 in the small 0.73 A/R housing.
Old Feb 18, 2012 | 04:02 PM
Ya im looking to be as high as i can be on pump with a built motor. Only have ****ty 91. Im in a debate between FP Black and EF4. I have a stock turbo lying around i could send out to FP
Old Feb 18, 2012 | 04:30 PM
Kracka's Avatar
This
Old Feb 20, 2012 | 08:15 AM
ChrisCarey's Avatar
We do upgrades as well
Old Feb 20, 2012 | 09:25 AM
chkmgnt59's Avatar
Either the ef4 or black will get you as high as a stock frame will go. The only difference is FP has ball bearing blacks, Map doesn't have ball bearing ef4's. So if you care about that, only 1 choice. If you don't care, the ef4 will be cheaper b/c fp doesn't offer jb blacks anymore.
Old Feb 20, 2012 | 09:42 AM
spdracerut's Avatar
With crappy 91 oct, I throw in the GTX3576 into the mix also. Then you would also have to chose between the small A/R or big A/R. Of course, the bigger one will make more power at the expense of spool.
