Engine problem [urgent]
Old Jun 15, 2012 | 12:22 PM
momostallion's Avatar
it's important to have nice clean gasket surfaces and only use new gaskets.
i would start with a razor to help get under a gasket to lift it off.
then you can use a solvent to help break down any remaining gasket material.
a wire brush (use copper or nylon on aluminum so you dont hurt the surface) or wire wheel on a low speed drill will give you a nice clean surface.
finally wipe down surface with a rubbing alcohol so it's grease free.
Jrod@Buschur
Jan 18, 2014 06:24 PM
Dem_z
May 27, 2004 02:20 PM
tom@kartboy
West Region
Aug 20, 2003 06:48 AM
