Use turbo gasket on divorced DP?
Installing my stock placement GTX30 right now and in putting it back together it dawned on me... should I even use the Turbo -> DP gasket? I'm running an UR 02 eliminator DP and it is completely divorced (not bellmouth style). If you use the oem gasket there would technically be a gap between the wastegate hole and the turbine hole outlet causing it not to be completely divorced? Again, because the gasket is a bellmouth type.
I tried doing some searching and only found one guy that mentions to NOT use the OEM gasket with a divorced DP because it would beat the purpose and there shouldnt be any leak issues. I wanted to get some advice before bolting everything up only to have to pull it all back off cause of a turbo-to-DP leak. Thanks for the help
dubs&boost
Apr 8, 2014 07:14 PM
