corrected ACD/AYC pump pic
Old Jul 28, 2013 | 10:10 AM
Iowa999's Avatar
If you've spent much time either trying to fix a dead ACD/AYC pump (in a USDM X) or just wanted to know how the system works, you've probably come across this picture:
Attached Thumbnails corrected ACD/AYC pump pic-evoxaycacdpumpcomponent.jpg
Old Jul 28, 2013 | 10:11 AM
Iowa999's Avatar
Well, the labels for the solenoids in that picture are wrong. Very wrong.
Here is a corrected picture:
Attached Thumbnails corrected ACD/AYC pump pic-correct_pump_labels.jpg
Iowa999's Avatar
And here are the relevant pictures from the FSM to back up my corrections:
Attached Thumbnails corrected ACD/AYC pump pic-ayc-connections.jpg
Old Jul 28, 2013 | 10:16 AM
Iowa999's Avatar
Let's not mention that the incorrect picture is from EvoXForums and that this is just one more reason to be here and not there, OK? oops tee hee
Old Jul 30, 2013 | 07:31 AM
Fencer's Avatar
Where is the AYC pump located? I was thinking of sealing the outside with silicon to prevent the internal corrosion problem.
Old Jul 30, 2013 | 08:32 AM
Iowa999's Avatar
On an Evo X, it's behind the right rear wheel. It is definitely worth sealing.
Old Jul 30, 2013 | 09:11 AM
modvp's Avatar
I am also considering protecting my AYC pump, do you have a procedure for sealing it with silicone or a similar sealer?
Old Jul 30, 2013 | 09:14 AM
modvp's Avatar
I think I may have found the answer to my question above:
https://www.evolutionm.net/forums/10227620-post1.html
Old Jul 30, 2013 | 10:10 AM
Iowa999's Avatar
Yes. Sealing it by pulling it out and coating it with a silicone sealant is a good thing to do. You can also devise or buy a cover (but that will also hold in moisture, so sealing is still important and maybe put some silicate packs in the box before closing it up). Or you can move it inside the trunk, if you're willing to give up the space and do the work.
Just don't leave it sitting there in the OE location without any protection, at least not if you live where they salt the roads in the winter. That's just asking for the need to get a new one, probably about ten minutes after the bumper-to-bumper warranty ends.
Old Jul 31, 2013 | 08:17 PM
beetle_orange's Avatar
Originally Posted by iowa999
let's not mention that the incorrect picture is from evoxforums and that this is just one more reason to be here and not there, ok? Oops tee hee
:d
Old Aug 1, 2013 | 01:22 PM
acidtonic's Avatar
Interesting.... I may look into this on mine too. In Michigan we salt the roads like mad.
I wonder if I can do what the other post mentions and just spray it with Motorcycle chain grease? They make it sound like you can seal it without removing it. I'm only at 12,000 miles under warranty and they might throw a fit if I've removed the ACD pump to seal it. Just seems like a good idea before I run into any corrosion problems.
Old Aug 1, 2013 | 05:00 PM
Iowa999's Avatar
If the corrosion isn't already working its way in through the cracks between the pieces of the pump body, coating it in silicone of some sort would be good. If it's already too late, that may be worse; I'm not sure. When trying to clean up my pump, I used something I hadn't seen before, called CorrosionX: http://www.grainger.com/Grainger/COR...130802000058:s Pretty expensive as those sorts of thing go, but it was absolutely fantastic.
Old Aug 2, 2013 | 09:27 AM
acidtonic's Avatar
Thanks. $13 isn't too bad for peace of mind about the ACD pump. I will be doing this next time I work on the car.
Old Aug 16, 2013 | 11:30 AM
nukerj's Avatar
I use corrosion x on all sorts of things- works good- its a heavier oil
Old Oct 6, 2013 | 06:54 PM
mar387's Avatar
Iowa, I checked the pump location and it looks like it is partially enclosed just like in the picture you posted. So I assume that salt and other contaminants get kicked up beyond the partially enclosed pieces of the pump, correct? If so, I assume in order to attempt to properly protect the pump in terms of sealing it with anti-corrosive spray, you need to take the enclosing apart?
Where I live, I don't have a jack or jack stands, so I'm trying to gauge the effort involved to protect the pump. I live in NJ and the car has been through one solid winter, and I'd prefer to try and save myself from spending thousands of dollars on a replacement or repair.
