machining a 4G for 1/2in studs
had a customer recently say that they needed to get their head machined for 1/2 studs by the shop doing the block so that they would match. These pictures show why that is not the case. Because in all reality, both shops are going to indicate or set the hole in the perpendicular to the cutter and cut. Same guy can machine both and destroy it or make it work. It's all about what all of us know something about, getting it straight in the hole!
First the hole is indicted in. We use a precision pin that is .002-.003 (2-3 thousandths) smaller then the hole. We use something smaller because you are looking for the pin to slide in and out the hole. If it's off it hits, and won't be center.
Here the match is made. We are center to the hole, and can now lock down the machine to cut in this exact spot with a end mill
Now that we change to the cutter, we make a swipe by hand just turning the cutter making sure that it is center and taking out the same material all around.
And BOOM we are cutting!!
Lukelis
Oct 5, 2014 05:06 PM
Pale Horse
38
Oct 21, 2013 11:46 PM
Headgames Motorworks
Oct 11, 2013 02:10 PM
evowner17
For Sale - Part Outs
30
Aug 26, 2013 10:50 PM
