problem starting car
Old Nov 17, 2013 | 08:27 AM
airman9911's Avatar
Ive went to start my x and twice now it almost didnt fire. No lights are on, battery is good. Dont know what section to put this in either. Looking to see if anyone else has this problem.
Old Nov 17, 2013 | 02:58 PM
Kracka's Avatar
What's it doing? Please explain in detail what occurs when you turn the key.
Old Nov 17, 2013 | 03:14 PM
TheBigD's Avatar
+1^ ill give an example..is it trying to start? is it free spinning? is it just clicking? is it backfiring? does it smell like fuel?
Old Nov 17, 2013 | 03:23 PM
airman9911's Avatar
No its trying to start. It just has a hard time getting there. Just have to hold the key turned for like 10 seconds. Has happened twice so far. Its not cold out either.
Old Nov 17, 2013 | 05:14 PM
rjfg's Avatar
My vote is the starter wire is loose.
Old Nov 17, 2013 | 06:08 PM
airman9911's Avatar
good vote, will try that tomorrow. Any others?
Old Nov 17, 2013 | 06:12 PM
littlezrexer's Avatar
Usually if the starter wire is loose or a bad connection it would click when cranking
Old Nov 18, 2013 | 04:33 AM
airman9911's Avatar
no, its not clicking. Its like it has lag, like an old car that hasnt been started that much.
Old Nov 18, 2013 | 05:12 AM
Than rule out The starter. It's most likely a sensor issue. Like the crank sensor or cam not getting a signal correctly.
Old Nov 18, 2013 | 06:29 AM
GodRealm06's Avatar
My car was having similar problems a few weeks ago. Turned out it was the spark plugs after it stopped starting.
Old Nov 18, 2013 | 03:35 PM
TheBigD's Avatar
have you taken it apart or messed with anything engine related latley? where you could have messed up a sensor or put something together wrong? if not fuel pump could be going on ya, or your compression is ****. have you confirmed you have no boost/vacuum leaks or even a compression test? or does she run strong once she starts?
sorry for all the ?'s, it could just be so many things depending on what you have touched or what its doing.
Old Nov 18, 2013 | 06:30 PM
airman9911's Avatar
shes running stronger after she fires, and havent messed with anything.
David Fogleman
Jan 20, 2010 12:08 PM
w0009722
Lancer Troubleshooting
Oct 22, 2009 05:49 AM
cosworthevo1133
AEM EMS
18
Jan 29, 2009 02:00 PM
raidokoiv
Oct 22, 2007 07:57 AM
aerialcombat
Jul 5, 2002 12:49 PM
