Car is running lean
Old Feb 13, 2015 | 11:53 AM
Sunset350ZR's Avatar
Car is running lean
Ok I have a 2011 GSR with a CB exhaust as only modification. Car will run fine but sometimes get a stutter under load going up hill. If I get on the gas and push it above 4k rpms I will get a CEL that reads lean more times than not. I have replaced many fuel pump relays and as recent as this month. Car has 33 k on the clock. I am really at my wits end and am about to put stock exhaust back on a go trade car if problem can't be resolved very shortly. Please help if you can.
Thanx.
Old Feb 13, 2015 | 07:10 PM
slvrevo84's Avatar
Im not sure what your particular problem is but im pretty sure its not the cbe..
maybe bad injectors/clogged?
Old Feb 14, 2015 | 04:01 PM
zebra4's Avatar
Check fuel pressure regulator hose and fuel pump relay. Both have been known to cause lean conditions.
jtbell86
11
Aug 1, 2020 09:23 PM
dli03
Apr 23, 2010 06:00 PM
race17k
10
Aug 6, 2006 01:21 PM
EVOnoir
Sep 21, 2004 07:58 PM
