Shudder above 60% throttle.
Old Apr 4, 2022 | 01:40 PM
Insanitystruth's Avatar
So on my 2010 MR I have an AEM Intake and Invidia N1 exhaust. When I go above roughly 60% throttle I am getting a violent rocking from front to rear. I'm thinking the car is leaning out on fuel since under 60% throttle it has no issues. So if this is the case should I get larger injectors since I'm still running stock injectors to resolve this or should I just get a tune?
Old Apr 16, 2022 | 01:31 PM
dsmhero14's Avatar
You have any way to show us a log? I highly doubt an intake and cbe is going to cause this, there is definitely an underlying issue. Did you double check all vacuum lines are connected??
Old Apr 16, 2022 | 04:21 PM
RazorLab's Avatar
AEM intake will lean the car out without a proper tune. Also make sure to check the fuel relay and make sure the FPR hose on the intake manifold didn't pop off.
Old Apr 16, 2022 | 10:28 PM
Sharkbite2000's Avatar
are you using a boost controller ? are you using blow-off valve?
wizechef
Nov 10, 2018 10:09 AM
CtSilver03Evo
Cobb AccessPORT
Apr 15, 2014 04:29 PM
jameswwt
Jul 25, 2012 08:50 AM
cirpower
Feb 27, 2005 10:18 PM
