-   Evo X Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-x-engine-turbo-drivetrain-258/)
-   -   The truth about BOV's (https://www.evolutionm.net/forums/evo-x-engine-turbo-drivetrain/383182-truth-about-bovs.html)
Black-X Nov 22, 2008 12:05 PM
Do they ACTUALLY do any harm? I've heard the same stuff that an atmospheric BOV will be bad since I had an 03' WRX, 04 STi, and now the Evo X. I had an SSQV on my WRX pretty much the whole time I owned it and I never noticed any problems (also had Perrin UP, DP, Blitz CBE, and UTEC).
Are there any solid FACTS about the BOV on the Evo X or any recirculative BOV systems? I have an Agency BOV that came with my car (stock BOV is on it now) when I bought it and I'm considering putting it back on for the hell of it. :p
Thanks!
-X
ShiftnDrift Nov 22, 2008 12:33 PM
i heard that the stock BOV is actually really good. If you want the BOV for the sound just get a intake. i might be wrong though, i'm a newbie with cars T_T
{offtopic} does anyone know where i can learn about the evo x and maybe cars in general? Like how the engines work, what components make up a car, etc...
salagahle2000 Nov 22, 2008 04:30 PM
You can deffinately damage your car if you don't set the spring pressure correctly. If the spring doesn't release when it's supposed to it will cause damage to the turbo wheel and bearings. If the spring pressure is to low then it will open under WOT and you will loose power. The stock unit is very good from what I've heard.
Mojito Nov 23, 2008 10:34 AM
After about 4 months, no problems with my SSQV:
http://media.share.ovi.com/m1/large/...96af48c6db.jpg
evokel Nov 23, 2008 10:37 AM
bovs are stupid.
just wait till you actually need one. dont do it for the noise
bluebyu36 Nov 23, 2008 10:43 AM
lol
mrfred Nov 23, 2008 04:11 PM
The stock DV is fine up to at least 25 psi, probably more. Unless you are going beyond 26 psi or you really like the BOV sound, stick with stock.
Sicks Nov 23, 2008 09:02 PM
can anyone confirm with proper AFR reading/logging software that it does in fact go pig rich in between shifts from not recirculating air thats already passed by the MAF?
i've had my hks set up both ways, vta at first and now recirculating. with the exception of periodic moments of eratic idling at first with it vta, i haven't noticed any changes in drivability either way.
CP9A-EVO Nov 23, 2008 10:09 PM
Mojito, does your SSQV come with the recirculation kit? If so, does it fit to the AEM inlet tube?
Mojito Nov 24, 2008 01:04 AM
No, it does not come with the recirculation kit, only with adaptor for it. This adaptor fits the AEM pipe.
EVOxStuntin2008 Nov 24, 2008 01:30 AM
Originally Posted by evokel (Post 6383563)
bovs are stupid.
Maybe some people (like me) enjoy that good old phssssh sound of a VTA BOV.
To each their own.{thumbup}
Sicks Nov 24, 2008 06:10 AM
bump for some proof. anybody got a wideband?
Q8_EVO Nov 24, 2008 06:13 AM
loool
does this fall under ... 19'd?
gotrnet Nov 24, 2008 06:16 AM
based on my wideband which is pegged out on the rich side at 10.0 you can't tell on a stock car at stock boost levels. it just seems to stay pig rich longer than it does with the recirc bov on the car. as you turn up the boost it leans it out more through the rpm range and it does go back to pig rich once you get off the gas. can't say it does any "Harm" but it does make you much richer coming off throttle.
i actually run a tial 50mm and switched to a blow through setup to keep this from happening.
dankaristo Nov 24, 2008 07:22 PM
is it just me, or is this the single greatest post ever?! LAWLZ
