-   Evo X Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-x-engine-turbo-drivetrain-258/)
-   -   Gears won't go in (https://www.evolutionm.net/forums/evo-x-engine-turbo-drivetrain/475413-gears-wont-go.html)
RREvoxGSR Feb 19, 2010 10:20 PM
Gears won't go in
Well tonight i was driving my car and my gears wouldn't go in, i just changed the clutch not to long ago. The gears go in when the car isn't on, and i have no idea what it is.
RREvoxGSR Feb 20, 2010 10:15 AM
bump i need to get this fixed soon, its my dd
Clipse3GT Feb 21, 2010 05:09 AM
I bet you installed the new TOB incorrectly or backwards...
boostin20 Feb 21, 2010 05:21 AM
Before you take the trans off again, does the slave cylinder move at all when the clutch pedal is depressed?
RREvoxGSR Feb 21, 2010 07:53 AM
no i'm sure the tob is in correctly, the clutch was changed around decemeber, i'll take a look at the slave cylinder.
boostin20 Feb 21, 2010 07:55 AM
Oh, december was a while ago; you should've added that in the first post. Was the car doing fine from december until now? How does the pedal feel?
Boltz. Feb 21, 2010 08:01 AM
If you can get into gear with the car off but not the car on, your clutch is dragging. You need to rebuild/replace your clutch. In the VIII and IX there is a clutch adjustment pedal which can help a little, but not by much.
Bighec Feb 21, 2010 02:41 PM
Clutch Master isn't leaking???
EvoXcrzy08 Feb 21, 2010 04:44 PM
hmmm? i dont think so. cuz the clutch master uses brake fluid. so if that was leaking he would have brakes. i think. anyone know if i am right?:confused:
Clipse3GT Feb 21, 2010 05:06 PM
The car isn't driving he doesn't need brakes.... :lol:
Bighec Feb 21, 2010 07:23 PM
Could be an internal leak in the clutch master. If that were the case I don't think it would affect brake fluid levels.
When the engine is spinning you need the clutch to engage a gear. When it isn't you don't need the clutch. If the clutch master is leaking whether it be internal or external it wouldn't allow you to engage the clutch.
RREvoxGSR Feb 22, 2010 09:02 PM
the car was running fine until now, the clutch pedal feels normal still. i've heard that i just might need to adjust my clutch pedal. master cylinder doesn't look like its leaking and brakes still work.
boostin20 Feb 23, 2010 01:50 PM
There's no clutch pedal adjustment on the X.
RREvoxGSR Feb 24, 2010 06:20 PM
well i just checked the slave cylinder and tob it's working fine.
Bighec Feb 24, 2010 07:11 PM
When you have the car off and are switching through the gears does it actually go into gear?
