Gears won't go in
Old Feb 19, 2010 | 10:20 PM
RREvoxGSR's Avatar
Gears won't go in
Well tonight i was driving my car and my gears wouldn't go in, i just changed the clutch not to long ago. The gears go in when the car isn't on, and i have no idea what it is.
Old Feb 20, 2010 | 10:15 AM
RREvoxGSR's Avatar
bump i need to get this fixed soon, its my dd
Old Feb 21, 2010 | 05:09 AM
Clipse3GT's Avatar
I bet you installed the new TOB incorrectly or backwards...
Old Feb 21, 2010 | 05:21 AM
boostin20's Avatar
Before you take the trans off again, does the slave cylinder move at all when the clutch pedal is depressed?
Old Feb 21, 2010 | 07:53 AM
RREvoxGSR's Avatar
no i'm sure the tob is in correctly, the clutch was changed around decemeber, i'll take a look at the slave cylinder.
Old Feb 21, 2010 | 07:55 AM
boostin20's Avatar
Oh, december was a while ago; you should've added that in the first post. Was the car doing fine from december until now? How does the pedal feel?
Old Feb 21, 2010 | 08:01 AM
Boltz.'s Avatar
FCOTM Winner
If you can get into gear with the car off but not the car on, your clutch is dragging. You need to rebuild/replace your clutch. In the VIII and IX there is a clutch adjustment pedal which can help a little, but not by much.
Old Feb 21, 2010 | 02:41 PM
Bighec's Avatar
Clutch Master isn't leaking???
Old Feb 21, 2010 | 04:44 PM
EvoXcrzy08's Avatar
hmmm? i dont think so. cuz the clutch master uses brake fluid. so if that was leaking he would have brakes. i think. anyone know if i am right?
Old Feb 21, 2010 | 05:06 PM
Clipse3GT's Avatar
The car isn't driving he doesn't need brakes....
Old Feb 21, 2010 | 07:23 PM
Bighec's Avatar
Could be an internal leak in the clutch master. If that were the case I don't think it would affect brake fluid levels.
When the engine is spinning you need the clutch to engage a gear. When it isn't you don't need the clutch. If the clutch master is leaking whether it be internal or external it wouldn't allow you to engage the clutch.
Old Feb 22, 2010 | 09:02 PM
RREvoxGSR's Avatar
the car was running fine until now, the clutch pedal feels normal still. i've heard that i just might need to adjust my clutch pedal. master cylinder doesn't look like its leaking and brakes still work.
Old Feb 23, 2010 | 01:50 PM
boostin20's Avatar
There's no clutch pedal adjustment on the X.
Old Feb 24, 2010 | 06:20 PM
RREvoxGSR's Avatar
well i just checked the slave cylinder and tob it's working fine.
Old Feb 24, 2010 | 07:11 PM
Bighec's Avatar
When you have the car off and are switching through the gears does it actually go into gear?
