I didn't realize that MBC's leaked so much..
From what I have been reading, if you run a boost test it is recommended that you plug the boost line off since it will leak there if not. Is that why boost tapers so much on them?
On a second note. I had bought the Hallman Pro (not the one with the stiffer spring) and i'm running 26-28 lbs is the stiffer spring needed? Will it hold boost better with it or would a Forge do better? |
No, it is a tiny tiny pinhole, such little air can escape it won't affect anything. Just needs to be covered during a test so you can hear other 'real' leaks.
MBC bleeds off less air than stock or a 3-port.
Sort of... the stock or 3 ports are 100% off during a pressure test, so they are bleeding nothing. If they do bleed, then they are broken.
I thought about giving the forge a try, but i'm not finished doubling all of the clamps on everything, I got it to hold 1.5 more lbs up top with what I have done so far, so i'll see how it is once I get the rest of them done. I'm pretty sure i'm just going to go with the gm 3 port. Is there a particular one I need to get? Or are all of them the same? Will the connecter connect to the OE one on the X?
The Hallman is a good MBC, definitely better than a Forge.
Originally Posted by Golden
(Post 8645136)
Originally Posted by Kracka
(Post 8645519)
Yup they have to have that little hole, otherwise your waste gate would not completely shut.
Originally Posted by scheides
(Post 8646547)
Stock solenoids are 2-ports, not 3; but yes you are correct in that they are closed when unpowered.
Not sure how to delete my reply, but it's not needed.. Missed some text above :D
| All times are GMT -7. The time now is 03:06 PM. |
