I didn't realize that MBC's leaked so much..
Old Sep 5, 2010 | 06:39 PM
Methodical4u's Avatar
From what I have been reading, if you run a boost test it is recommended that you plug the boost line off since it will leak there if not. Is that why boost tapers so much on them?
On a second note. I had bought the Hallman Pro (not the one with the stiffer spring) and i'm running 26-28 lbs is the stiffer spring needed? Will it hold boost better with it or would a Forge do better?
Old Sep 5, 2010 | 10:50 PM
scheides's Avatar
EvoM Moderator
No, it is a tiny tiny pinhole, such little air can escape it won't affect anything. Just needs to be covered during a test so you can hear other 'real' leaks.
Old Sep 5, 2010 | 11:05 PM
Kracka's Avatar
MBC bleeds off less air than stock or a 3-port.
Old Sep 6, 2010 | 07:38 AM
Golden's Avatar
Sort of... the stock or 3 ports are 100% off during a pressure test, so they are bleeding nothing. If they do bleed, then they are broken.
Old Sep 6, 2010 | 10:39 AM
I thought about giving the forge a try, but i'm not finished doubling all of the clamps on everything, I got it to hold 1.5 more lbs up top with what I have done so far, so i'll see how it is once I get the rest of them done. I'm pretty sure i'm just going to go with the gm 3 port. Is there a particular one I need to get? Or are all of them the same? Will the connecter connect to the OE one on the X?
Old Sep 6, 2010 | 10:51 AM
Kracka's Avatar
The Hallman is a good MBC, definitely better than a Forge.
Old Sep 6, 2010 | 07:54 PM
scheides's Avatar
EvoM Moderator
Stock solenoids are 2-ports, not 3; but yes you are correct in that they are closed when unpowered.
+1 but I wouldn't say it works any better than a Joe-P or even an old-school hallman. I've just heard and seen a lot of 'meh' with the Forge stuff.
Old Sep 6, 2010 | 08:05 PM
SyZyGy1394's Avatar
Yup they have to have that little hole, otherwise your waste gate would not completely shut.
He said "the stock or 3 ports".
Old Sep 7, 2010 | 11:01 PM
saytheb's Avatar
Not sure how to delete my reply, but it's not needed.. Missed some text above
jameswwt
Feb 11, 2020 05:53 AM
nspyr
26
Jun 20, 2017 02:08 AM
bbyevo8u
Apr 24, 2011 08:55 AM
tsitalon1
Aug 24, 2010 07:26 PM
tearitdown9
Jul 12, 2010 07:28 AM
