Turbomart BOV Flutter/Surge
Hey guys i just recently installed my turbosmart BOV and ive been having alot of flutter/surge, you cant hear it at high boost but its bad at very low boost when i slightly press the throttle. I looked everywhere and people are having the same problems and others say that they have zero problems. Im confused:confused: I tried setting it at soft and hard and in between but no use, im running the mods that are in my sig btw. Im also running recirculated not VTA, any ideas to whats causing the flutter??
Turbosmart BOV flutter Fix!!! *Update* So i was in socal yesterday and turbosmart was able to open up their shop on a day that they are closed just to fix my BOV, great customer service! They told me since i have an exhaust, test pipe and an intake i freed up the car more its breathing way better so in order for the BOV not to flutter you really got to mess with it. The solution however is the spring, the tech their said that changing the spring will fix the flutter right away and once he installed it, it was easily fixed! No more flutter and the BOV sounds great, it holds boost great:) I like to give a shout out to Marty at Turbosmart for the great customer service:) |
How long have you been using this BOV? Have you taken it apart and cleaned/lubed it yet? I had the same problem when I ran the turbosmart. They usually get junked and need to be cleaned. I got tired of the problems and just put the OEM bov back on.
i just bought it :( i called turbo smart and they are gonna call me back later
bump!
Well turbosmart never called back, i tried everything to make the flutter go away, i bought a new hose to see if maybe the hose was cracked, i lubed the BOV to see if that was the problem and i check all my hoses and piping to see that was the cause and no im still getting flutter:( |
ive been running a turbosmart for about 1.5 years no issue. sounds exacty like that minus the surge. only fluttering i get is low boost/rpm. can you take a distant picture?
Originally Posted by SpeedI2acerX
(Post 9983591)
also when i get on it i hear the normal loud woosh but thier is also some flutter right before it |
i assume its normal, so ive been told. if it worries you maybe you have to change your way of driving, keep the rpm/boost up.
(Post 9983774)
Updated the first post guys, i fixed my flutter:)
Originally Posted by GgreyEVOIX
(Post 9982916)
Also you have to set it perfectly not to flutter.
Look at my original post guys it's fixed thanks to Marty from turbosmart:)
