Evo X Acceleration Issue ?!!
Soo
i was driving Evo X SST The other day, it was on normal Automatic mode i was on the high way and i pushed 50% Throttle, the car started to rev until it hit about 5,000 RPM and the turbo started like a weird Surge/Flutter. so i released the throttle and decided to stop and change it to sport mode Manual, i go to about 60-70mph on 4th gear and i pushed WOT (Wide open throttle), the Rpm started to raise and the turbo started to spool, But the problem now is it doesnt give that constant feel of spool up and acceleration, its more like the rpm raising and stopping momentarily. so my question is why is the car reacting to WOT like this ? BTW it has Bolt-ons , FP Green , dyno-tuned by professionals |
Do you have a Air Fuel Ratio Gauge?
Originally Posted by cdmassee
(Post 10930610)
I shouldn't put words in the mouths of others, but I have a gut feeling that when cdmassee asked whether you had a AFR gauge, he or she was asking what the ratio was when the problem occurs.
But the problem now is it doesnt give that constant feel of spool up and acceleration, its more like the rpm raising and stopping momentarily. |
Originally Posted by Iowa999
(Post 10930773)
Thank you Iowa. That was going to be my next question. then my next suggestion: if the AFR was reading above 13-14 when in boost, check the fuel pump relay. (I lost a motor because I didnt have a AFR gauge and my relay went out) and from what youre describing the car is doing similar to what mine was. *Im not trying to frighten you at all. It may be something very simple and harmless. but better safe than sorry. |
(Post 10931877)
This is entirely correct.
Thank you Iowa. That was going to be my next question. then my next suggestion: if the AFR was reading above 13-14 when in boost, check the fuel pump relay. (I lost a motor because I didnt have a AFR gauge and my relay went out) and from what youre describing the car is doing similar to what mine was. *Im not trying to frighten you at all. It may be something very simple and harmless. but better safe than sorry. This is a weird problem that happened to me 2 times only, and they both happened after that kind of weird surge at 5,000 rpm im worried that this may damage something really expensive in the car :( |
is there a shop that you can have took a Quick look at it nearby?
was it solved man?
can u tell us how? |
The problem happened to me 2 times only
and it runs normally the next day without any problem i will take it to a nearby shop and try to find out whats happening ;) |
Originally Posted by xSoLD3Rv
(Post 10933960)
and it runs normally the next day without any problem i will take it to a nearby shop and try to find out whats happening ;) btw i stay in saudi (fuel damn bad hihi) |
