Help! No oversteer!
Dear all,
I'm in a bit of a muddle, properly disoriented and unable to understand. Ive read most posts on how to get power oversteer yet I cannot find why my car is not oversteering so my car is a 2.2 gtx30 tuned to 450ponys I have a quaife limited slip infront, and an RS diff at the back. AYC still functions and I put on the least aggressive setting i.e, tarmac. I also have ohlins road and track....and whiteline rear anti roll bar installed. Yet this car does not only not power oversteer yet understeers greatly in tight corners I cannot understand, and have no clue how to make this right! seriously I need help. Thanks Chassis |
Well aside from this being the wrong section.. Ill try to help if I can. So You need to turn off any traction control to make sure the ecu isn't sensing a slide and cutting or transferring power, also what are your alignment specs because that is going to play into how your car is handling.
Whats the setting on the rear bar as well. I assume its adjustable?
Sound like you need a more aggressive diff in the back. Look into a 1.5 way setup.
-pal215 |
Originally Posted by hoobastnk90
(Post 11551578)
ohh dear....yes sry mine is a CT9A as far as I know I don't have TC on my evo...its a uk model. Only abs it has. alignment specs are factory std |
What is your current alignment? Do you know the spring rates on your Ohlins? And care to provide any videos or further info on what types of corners and how you are approaching these corners. Sure your setup could have a lot to do with the cars inability to oversteer but often times driver technique plays an even bigger role.
For example my car is setup extremely loose and my driving style is very aggressive so I generally end up sliding all over the place. Another guy I race with, who admittedly is a superior driver to me on the same course same exact sections where Im sliding sideways he ends up pushing. Totally different driving styles same exact setup yet different results. Thankfully he has yet to beat me in my own car but that is besides the point, lol! All Im getting at is that sometimes its not the car but rather the driver. |
Originally Posted by meckert
(Post 11551581)
I bolted mine on the first hole. Infact as a side question....would bolting it through the 3hole i.e. the most inwards hole make it tighter? Thanks chass |
Originally Posted by heel2toe
(Post 11551595)
For example my car is setup extremely loose and my driving style is very aggressive so I generally end up sliding all over the place. Another guy I race with, who admittedly is a superior driver to me on the same course same exact sections where Im sliding sideways he ends up pushing. Totally different driving styles same exact setup yet different results. Thankfully he has yet to beat me in my own car but that is besides the point, lol! All Im getting at is that sometimes its not the car but rather the driver. re suspension set-up using coils that came with ohlins running very 3clicks soft front and 3clicks soft back....we have dirty and bumpy roads re cambers and toe in...all standard ct9a settings done accurately using a laser wheel alignment (from a professional garage) |
it's the rear diff. AYC won't work with it if you've swapped in mechanical. ACD, on the other hand, doesn't do TOO much in the power oversteer regard.
put in an aggressive rear diff, like a cusco or an os giken, and it will, pending the rest of your set up. |
Well not to sound rude but your competition prolly wont like your set up anyways if it already does not work so I don't think posting here will matter. Escpecially if its in the evo x section.
(Post 11551666)
the admins can move my post whenever they like....don't know if I can do it, already apologized for this. |
Originally Posted by kyoo
(Post 11551662)
put in an aggressive rear diff, like a cusco or an os giken, and it will, pending the rest of your set up. so technically speaking now....what I don't understand is what is the use of the ACD? Its a center diff but with front and rear mechanical diffs....doesn't it become redundant? Cause I just need to jam it on tarmac since its the least amount of lock and let it be? correct? |
ACD keeps the front and rear axles paired, its the center differential. It prevents the front tires from spinning up when the front of the car gets light, or when the rear of the car has more grip, as when you're turning. You actually want more aggressive ACD settings to make the car rotate.
Originally Posted by chassis87
(Post 11551598)
as far as I know there are 3 holes, to select from on each side.
