Evo X MR leak
So recently after being out of town for 2 weeks, I left my wife with my evo to use since our other car would be in the shop. As I came back home she greater me with. "Oh hun there is an oil leak under the car". You can Imagen my face when I heard it, lol. How ever I took a look at it and I found a Crack about 1 inch in length (more or less) under the ear. It's not on the transfer case side. No idea what to call that. Any idea how much would it cost to repair? Or weld back togethe, or would it just be better go to get that ssp upgrade I've heard much about? F.I.Y. I live in the Houston area. https://cimg7.ibsrv.net/gimg/www.evo...2a9873f571.jpg
https://cimg8.ibsrv.net/gimg/www.evo...ff52caeab5.jpg |
Bump
clean it up really well, and put some jb weld on it and see if that fixes it.
Originally Posted by hoobastnk90
(Post 11669877)
Transmission case is likely ruined. Ask your wife what she ran over. That's going to be expensive.
Well ****,I asked her and apparently there was a rock she didn't see on the road and pretty much run it over. the hole bottom plastic shielding was torn from the drivers side.
I would try to claim it on your insurance. That is not going to be a cheap repair bill. Someone in Vegas was able to do it. Just need to make sure it is is very clear you weren't able to avoid the rock due to cars around you or whatever. The person that did in Vegas, the insurance paid for a brand new tans from Mitsu, with install. Its was like $15k. You could take that money, send the trans (or the whole car) to Kozmic, have them do whatever they can, and it will likely be way cheaper, even if you have to buy a used core and get it built. You'll put some money in your pocket.
Damn......
(Post 11670250)
Well if the crack is just causing the trans to leak and if your insurance shuts you down, I would again try the jb weld. I mean its not the ideal fix but it may work, I mean this crack isn't on the engine block itself.
(Post 11670333)
It's just on the bottom of the trans casing, if it was the engine block I would be a divorce man by nonow since it's a 2.2. |
If you are in Houston, try go see Kozmic Motorsports.
Originally Posted by ALEX9X
(Post 11670343)
take it to kozmic and see what they say, its better to have them give you the full detail and damage report then start calling the insurance and see.
(Post 11670317)
Sounds a bit risky, but at this point that sounds like the best option. But I'm always open to suggestions
Example: Like a month after I got my 8, someone broke the wing and messed up the decklid. Bod shop estimate was $2k for repairs. Insurance cut me a check for the $2k estimate, I bought an CF Do-luck style trunk lid for like $800 and pocketed the rest. In you're case, you'll have a mItsu service center estimate a new trans and install about $15k, then take the car to Kozmic and fix for likely a good bit less, and you'll have a built trans instead of a new stocker. |
