Sponsored by:
Sponsored by: CARiD
Evo X Engine Manual et al
Old Dec 23, 2007 | 12:57 AM
madfast's Avatar
http://www.onlinefreeebooks.net/auto...anual-pdf.html
i dunno if this has been posted before but it's new to me i just found these awesome links about the 4B11 and what is supposed to be the Evo X but it's just the regular lancer. you can tell the engine spec is from the GTS by the 10.0 compression vs the 9.0 for the evo x.
the main thing i wanted to find was the rod length...149.25mm!!!!
this makes a 1.735 rod ratio on the 4B11 which is friggin AWESOME.
other interesting numbers are valves: 35mm int/29mm ex and cam lift: 8.45mm int/8.20mm ex
Old Dec 26, 2007 | 09:46 AM
AREITU's Avatar
Thanks for sharing the find!
Could you compare those numbers to the 4G63's?
Old Dec 26, 2007 | 10:26 PM
madfast's Avatar
4G63 is 85 x 88 with a 150 mm rod so the resultant rod ratio is 1.71. deck height is 229mm. awesome numbers for an awesome, legendary engine.
the 4B11 is very similar and in fact slightly better looking strictly at the numbers. time will tell how good this engine is
Old Dec 27, 2007 | 04:27 AM
Robevo RS's Avatar
yes i thought so,by numbers the 4b11 looks better then 4g63.
