Sponsored by:
Sponsored by: CARiD
X Launching
Old Jan 10, 2008 | 03:48 PM
DoHBoY's Avatar
X Launching
Has anyone found anything about a launch control? i saw mention of it but no information.
I am hoping it's like the DSG. If not i hope it has enough power to break stand unlike the current 08 lancer
Old Jan 10, 2008 | 03:59 PM
machron1's Avatar
SUPPOSEDLY...from what I've read...and for which i have no reference...you put the tc-sst in super sport mode, and turn the asc off to some degree. then, while holding down the brake, floor the gas. then, release the brake and you should be on your way in a hurry. sounds like a great way to get on the freeway when stopped at an annoying traffic metering light placed on a short on-ramp...assuming you don't run up the back end of the car in front of you if present...
Old Jan 10, 2008 | 04:32 PM
RussellM's Avatar
Plat Vendor
I dont have an answer for this either. Im sure things will being popping up left and right for this though.
Old Jan 10, 2008 | 05:51 PM
cksdayoff's Avatar
- switch to super sport mode
- step on gas and brake
- rev to 5000 rpm
- release brake
Old Jan 10, 2008 | 09:29 PM
EV0LVE's Avatar
this procedure on any other car is bad, i don't know about . I tried this on a loaner c230, while it worked, i smelled something burning afterwards. We'll see...
Old Jan 10, 2008 | 09:30 PM
FLK's Avatar
FLK
- rev to 5000 rpm
- release brake
I think that's the regular launch control. Does the 1/4 in ~13.7
There is a secret mode without the brake launch, involves fiddling with ASC or something I forget. This gets ~13.6 in the 1/4.
Old Jan 10, 2008 | 09:40 PM
08LancerEVO's Avatar
^ there was a vid posted here someware that showed that
Old Jan 10, 2008 | 11:44 PM
machron1's Avatar
I don't think your loaner c230 had a sequential manual gearbox...nor will the Benz ever see the start of a rally stage...so I doubt they included launch control
Old Jan 11, 2008 | 12:00 AM
boomtown's Avatar
Given the tendency of OEM clutches to fry (and for the transfer cases to shatter after the OEM clutch is replaced) on heavy launches on VHT surfaces I am fairly wary about the ability of SST to take drag strip launches. If the car is going to be launched regularly it might be better to go with the 5 speed which is a known beast.
But I will happily wait and see.
Old Jan 11, 2008 | 05:33 AM
mihaley's Avatar
a c230 does not have launch control, i worked for mercedes benz for a few years
Old Jan 11, 2008 | 05:49 AM
Redline06's Avatar
The SST X launches way slower than a Regular 5spd X.. hence why its slower than the X at the 1/4 mile.. all though there are some reviews where the X SST is faster than the X 5speed.. but that's all due to them not launching the X 5spd..
Old Jan 11, 2008 | 08:36 AM
EV0LVE's Avatar
where did i say launch control? maybe pre-loading...just keep doing it and see how it works out.
Old Jan 11, 2008 | 09:08 AM
Guerillah's Avatar
The launch control works fine on the GT-R with a DSG tranny but it could be more beafy than the evo x's... At least theres hope if it is strong enough, changing the TCU may enable a launch control that rivals that of a manual.
