Sponsored by:
Sponsored by: CARiD
Do all Evo X models have TPMS?
Old Feb 5, 2008 | 11:15 AM
CRX2EVO's Avatar
Originally Posted by wokuku
There are also drivers who overinflated their tires! One time I was at the gas station waiting for this korean couple to finish inflating their tires. I watched them spending about 5 - 6 minutes per tire without actually checking the tire pressure
I see people at my local station filling tires ALL the time. I just have to laugh because they have no idea what their tire pressure is.
Old Feb 5, 2008 | 11:53 AM
PDXEvo's Avatar
What is the impact of changing to a wheel that does not support this device? Does it throw a CEL? If so, then can it cause a failure at DEQ?
Old Feb 5, 2008 | 12:25 PM
Ludikraut's Avatar
If you remove the TPMS sensor, then a separate TPMS idiot light should start to shine. I believe that it's a universal symbol, since it's the same on both my R32 and Forester.
l8r)
Old Feb 5, 2008 | 12:28 PM
Karan's Avatar
It will probably beep everytime you start the car, or open the door. And flash all sorts of warnings on the LCD screen
Old Feb 5, 2008 | 01:04 PM
xtnct's Avatar
Can you just delete that system outright? put on some resistor somewhere on the wire faking it to think all is ok. I'll be just fine without it as I look at my tires each time I go to the car and second, I can feel it if the tires are not inflated properly so I really don't need it or want it, or want to deal with extra sensors and crap on spare rims, etc.
Old Feb 5, 2008 | 01:17 PM
Noize's Avatar
EvoM Administrator
Originally Posted by Ludikraut
Does anyone know what the recommended and max pressure ratings are for the new Advans that come with the X?
l8r)
I have not caused the TPMS in the Evo to activate yet, but I had a lot of experience with the TPMS in my 335i.
Basically, you reset the system and it looks for a variance, quick loss, or leaks. I could pump the tires to their maximum pressure if I wanted (44psi) and reset, or to a really low level (28psi) and not cause the system to intervene. When I got a leak in the tire, the system would throw a light and require a reset.
When you change tires, you don't need to worry, the TPMS should last the life of the car if your tire guy does not damage them. You would only need them if you bought new wheels and wanted the light to go out.
Hope this helps.
Are you considering an Evo X, Ludi?
Old Feb 5, 2008 | 03:23 PM
Ludikraut's Avatar
Possibly, although not for at least another year. It would allow me to 'retire' the VIII from street duties and turn it into a track only car. I've been fairly impressed with the X so far, but I'll wait to pass final judgement until I've driven a GSR and an MR.
l8r)
Old Feb 5, 2008 | 03:35 PM
kidneythief13's Avatar
So does the pressure info display on the new screen, between the sped & the tach, if you don't have the navi?
