Sponsored by:
Sponsored by: CARiD
Fog light question.
Old Apr 7, 2008 | 10:09 AM
Dosagex's Avatar
Fog light question.
What size are the fog light bulbs on the GSR(halogan)?
"SSS" i believe uses Bixenon HID bulbs correct? and also do the fog lights on the SSS package have HID's?
Thanks.
Old Apr 7, 2008 | 10:26 AM
Rguy's Avatar
No the fogs wont be HIDs. Most likely a 9006 projector bulb, but im totally guessing.
Old Apr 7, 2008 | 10:36 AM
n789db's Avatar
Thanks.
As he said the fogs are NOT HID. Also, Bi-Xenon is NOT the bulb it is the projector assembly with a solenoid activated "cut off" shield which makes it Bi-Xenon.
Old Apr 7, 2008 | 10:45 AM
R0ME0's Avatar
They use H11 Bulbs and are not xenon unless you decide to convert.
Old Apr 7, 2008 | 10:53 AM
Dosagex's Avatar
Basically the ballast has to support bi-xenon?
Old Apr 7, 2008 | 12:09 PM
Dosagex's Avatar
what is the bulb size for the HID's?
Old Apr 7, 2008 | 12:15 PM
n789db's Avatar
The ballast has NOTHING to do with BiXenon. There is likely a seperate relay which controls the solenoid for moving the cut off shield.
The HID bulbs are D2S from Osram 4200K color temp.
D2S Bulbs from GE or Philips can be used as a direct replacement in place of the Osram (Sylvania) brand.
