Sponsored by:
Sponsored by: CARiD
Custom Cold Air AMS intake box.
Old Jul 30, 2008 | 03:01 PM
darkzschneider's Avatar
Ok today I made a custom Cold Air AMS intake box.
I have no idea if it's going to effect performance good or bad..
But I just wanted to try it out.
I bought all of the materials at HomeDepot, it cost around $20-30 tops.
BEWARE super ghetto rigged!
Heres some pictures-->
The pipe goes to the bottom of the intake box forcing cold air in.
Old Jul 30, 2008 | 05:21 PM
scottatyamaha's Avatar
How cold you think that air will stay when it goes through that turbo?
Old Jul 30, 2008 | 05:24 PM
AWD Motorsports's Avatar
colder air in is still colder air out of the turbo.. Im not sure if this design will work at all but thats what testing is all about.. Good luck to the OP for giving it the ole college try!!
Old Jul 30, 2008 | 06:33 PM
Alifx's Avatar
I would widen the hose on the bottom air dam or put a funnel or anything like that, you need to maximize airflow to that hose (which i'm assuming is going to the intake box ;p) , its going to be way more efficient... but the way you have it set it up right now, you're losing a lot of air .. but good job its a really creative design
Old Jul 30, 2008 | 09:24 PM
Poppy9's Avatar
This is the funnel on the bottom.
I do need to make a funnel on the other side.
BTW DarkZ is my bro that was helping me with this.
Old Jul 30, 2008 | 09:47 PM
Hiboost's Avatar
The concept is sound, just a matter of making it have a more finished look. I made a cold air box for my Evo 8 and 20-30 degrees cooler air entering the turbo does help quite a bit. It may only be 5-10 HP but that's better than nothing! I would use at least 4" ducting and like others have said having a funnel at the entry from the front grill is likely the most important place.
Old Jul 30, 2008 | 11:53 PM
BigmikeOC's Avatar
Nice project. I'm not a super fabricator myself but I think eventually you would want to spend some time to make that box out of some aluminum that you polished or painted. You might also want to rivet it all together. Making the box itself a square or rectangular shape would simplify the task. As for the connections between the piping and the box, you might find some rubber strip or weatherstrip to make that more "pro" without the duct tape or at least apply the duct tape in nice straight lines.
Old Jul 31, 2008 | 10:10 AM
Poppy9's Avatar
the Box also fixes the problem of having a open element filter with the AC on at idle. So now i can sit there with AC on thats really why i build it its a lot cheeper then buying Bushers filter air blocker..
Old Aug 5, 2008 | 10:28 AM
DirectorSe7en's Avatar
Wow, that actually looks pretty good.
Nice job.
Old Aug 5, 2008 | 10:36 AM
mdsevo06's Avatar
It's not the cold air after the turbo that this would help, it's the cold air moving thru the MAF. If it was a stand alone, you wouldn't need any shield at all and just let the IC do it's job.
Old Aug 5, 2008 | 11:06 AM
StevenStarke's Avatar
took the words off my fingertips
Old Aug 5, 2008 | 04:23 PM
honeybadger's Avatar
Did you notice any changes after doing this mod?
