Sponsored by:
Sponsored by: CARiD
How to raise the driver's seat
Old Oct 7, 2008 | 09:29 AM
strife's Avatar
Isn't raising the seat going to make it feel awkward for you to drive.
Old Oct 7, 2008 | 10:11 AM
Web9's Avatar
Most likely not. The seats sit pretty low to begin with. After I raised the back of the seat 1 inch, I still have plenty of head room and I'm 6 ft. tall.
Old Oct 7, 2008 | 10:25 AM
Capone X's Avatar
web9 you have saved me a headache, my wife is also 5'3 and i would also like her to drive the X more. The seat height in her 99 GST just fine but she complained about sitting so low in the seat in the evo x
Old Oct 7, 2008 | 10:49 AM
bli8's Avatar
One concern I have with changing the rake too much is that it seems the design of the bottom cushion of the seat and rake is to prevent the driver from submarining into the dash in case of an accident and if we change it too much, the belts won't be able to do as good a job in prevent the driver from sliding downward in an accident. Therefore, I think we should also look at raising the front to a certain degree.
Old Oct 7, 2008 | 11:53 AM
si_to_evo's Avatar
why not just buy height adjusting rails i am sure they are available?
Old Oct 7, 2008 | 09:33 PM
bli8's Avatar
I don't think there's any height adjusting rails on the market, just a higher bracket is available from HKS. But it costs $250 vs. the cost of just 4 spacers and bolts.
Old Oct 8, 2008 | 04:20 AM
strife's Avatar
@ web9
That makes sense but I got it in my head that when your seated lower in the car it just feels "right" for a faster car. The faster I corner the safer/more control I feel when seated lower to the ground. I know its just in my head though.
Old Oct 8, 2008 | 05:13 AM
goofygrin's Avatar
Honestly, I want the seat lowered... but I really wish the steering wheel telescoped!
Old Oct 8, 2008 | 11:38 PM
salukidude's Avatar
Dude get a taller gf. Leave those shorty's for us shorter guys.
Old Oct 9, 2008 | 09:33 AM
weneversleep's Avatar
You know, the one problem that I have with the Evo X seats is that the seat is too low in the FRONT.
I could use about a 1/2-1" lift in the front section of the seat. My thighs don't touch the bottom of the seat when I'm driving.
--michael
Old Oct 9, 2008 | 11:57 AM
Web9's Avatar
--michael
Just reverse what I did then and use the spacers in the front.
Old Oct 9, 2008 | 03:57 PM
wongck's Avatar
This looks like a good solution, I will look into it
Old Oct 10, 2008 | 08:16 AM
evilbada's Avatar
Get her to go under bone elongation surgery and leave your precious evo unmolested. hehe
Old Nov 22, 2008 | 02:36 PM
dcgsr's Avatar
Thanks!
Very easy to do. I didn't like the angle of the seat (felt like I was always trying to lean forward), so I raised the back 1 inch. Got all the hardware at Lowes. No need to use a bunch of washers, they have some nice SS spacers. Torque specs for the bolts is 32 ftlbs. BTW.
Pics attached.
Hope that helps.
Thanks Web9 - I just did the spacer-mod for myself. Works like a champ.
The bolt measurements are 10mmx1.25.
Home Depot didn't have any metal spacers 1" long, so I also ended up going to Lowes and finding everything I needed.
Total Cost: $24
4 x bolts (Grade 8 quality - the bolt it replaces was Grade 7)
12 x washers
4 x locking-washer
4 x spacer
Old Nov 22, 2008 | 02:58 PM
Under PSI's Avatar
Be very cautious changing seat bolts. Unless you use the appropriate type of bolt, they could shear off and then your wife/gf etc becomes a projectile rather than a passenger. Modding the car as you have with bolts from a hardware store may save you a few bucks now but safety is not were you want to cut corners. I am sure there are numerous upholstery shops that could easily, and relatively inexpensively, put in a taller cushion. That would solve your problem and not put you or your gf at risk.
