service change light
how do i get this sh** off man.. i have done oil changes every 3000 (2 total 7,000 miles) and did put better tranny and diff gear oil in.. what could be the problem.. its been on for a day and a half.... help!! its annoying
check the manual-or search the threads around here-you can change the distance/time set up, turn it off completely, ect.....iirc-with the car off-cycle thru until the wrench comes up, hold it in for 3-5 sec (beep) and it "should" reset. If not-do the same start, then push in 3 times to access the menu.
When i start my car.. an amber wrench come up with a some japanese writing underneath it and then quickly disappears to the normal display with engine temp and fuel guage. Is this normal?
where you are at-yep. JDM baby. Pretty soon-you'll have us white guys asking you how to get the Japanese to appear on our cars.....do you think Chinese people walk around with english words as tattoos? Hey Cheng-check out this-it says "Water" "Hey man-thats kewl".....sorry....
... do you think the light is going to know when to reset itself?
its not the wrench i have already done that...its the engine service soon light that is up in the right hand corner...do you guys think i have to take it to the dealer to take it off.??..i tried to disconnect the battery to reset but no luck...ill search to see if anyone has dealt with it..thanks for the input guys.....
so...the check engine light is on? I guess I never saw a SES light on my dash...if thats the case-take what ever mod you just put on off.....and check the vac and boost hoses.....if it wont turn off after the battery has been reset...thats not good.
The language selector is one of the menu items .. 3rd or 4th I think .. press and hold .. you'll see a selection of languages coming up .. .. take your pick
so agree with that....seriously...why I know it prob means someting...but come on. Its a character from another language. I want Sandscrit or Farsi on the base of my neck-ooohhhhh.....a bar code! I want a bar code! One for Doublemint gum-so's I can ring up
