Sponsored by:
Sponsored by: CARiD
What would i need to get 350WHP?
Old Dec 1, 2008 | 11:42 AM
TrueX's Avatar
Hey guys and girls, i am new to the site and loving the site so far... I have a question for ya'll. I am curious what parts should i get to get 350WHP out of an evo x GSR ?? Thanks!
Old Dec 1, 2008 | 11:45 AM
Rguy's Avatar
FP Red, turbo back exhaust, tune.
Anymore questions?
Old Dec 1, 2008 | 11:47 AM
TrueX's Avatar
What is the FP red? sorry for the newb question.
si_to_evo's Avatar
Will it possible to make an aftermarket turbo that will retain the same boost as stock turbo?
Old Dec 1, 2008 | 11:48 AM
Rguy's Avatar
Its a bigger turbo. look up a company called forced perfomance.
Old Dec 1, 2008 | 11:52 AM
TrueX's Avatar
Thanks! Is the stock turbo not good for 350WHP? i didn't want to have to do to much changing to the turbo etc..
Old Dec 1, 2008 | 11:53 AM
Robevo RS's Avatar
sorry double post. i messed it up a big time
Old Dec 1, 2008 | 11:55 AM
Robevo RS's Avatar
Originally Posted by Robevo RS
you can do it on stock turbo no problem. Get a supporting mods for the bigger turbo and you will find yourself over 350whp with tune .
supporting mods can be a following
Intercooler and piping,
Turbo back exhaust
intake
fuel pump
cams
Injectors
Boos controller/if you want it/
and when you got more money and you get used to the added power, you can go for bigger turbo .
And you will shoot over 400 whp easy.
Old Dec 1, 2008 | 11:59 AM
TrueX's Avatar
So there is no way of making 350whp without cams or fuel pump etc.. Then what would i be able to achieve with stock turbo and bolt ons with a good tune? THANKS GUYS
Old Dec 1, 2008 | 12:09 PM
godmiller10's Avatar
yes there is a way without cams.
First off, get yourself a Turboback exhaust, cold air intake, front mount with lower pipe, boost controller, fuel pump, and tune. This should make you close.
Then if you want more prolly go lil bigger injectors, cams, and a quick spool up turbo. This will set you damn close to 400whp depending on dyno
Robevo RS's Avatar
you can actually achive the 350 without cams. But i like it this way. Every body has a different taste.
You can do meth etc. or running higher boost with higher octain fuel and so.
Bu i like this route better , since it will give you a great base for the next step.
Old Dec 1, 2008 | 12:17 PM
JoeyM3's Avatar
like rob said you can run meth, or also you can run e85. both of those with supporting mods will easily put you over 350whp mark
Papi4baby's Avatar
How about some juice!!!
Old Dec 1, 2008 | 12:20 PM
TrueX's Avatar
ummmm i see, where can i find some good cams at?
Old Dec 1, 2008 | 12:43 PM
apagan01's Avatar
350 is a walk in the park specially with a GSR,,, get a hold by pm of Xtrmeboost, he has mannaged to get a very clean evoX to go very fast which is their shop car
