WTF is wrong with my Evo?
The EXACT same thing was happening to me and it just got worse, I knew it was clutch slippage. First time I took it to the dealership and they it was fine, this was when it was mildly slipping but enough for them to notice though. Second time I took it in, about 3 weeks later and they said "oh your clutch might be slipping"
. Needless to say the third time I took it in it was shot and now they wont cover it under warranty. WTF!!!!
Getting a ACT Street clutch put in this week.
i have about 5000 miles on mine and took it in to the dealer to find out about the clutch around 3000 miles(it has been slipping since day one). basically because mitsu says that the clutch is a wear part they dont have 2 warranty it (total bs), or i quote= they would take the car tare it apart call mitsu and have someone come out and inspect it if abnormal where is found it must be "bad driving habits" and they will not warranty it. plus the factory clutch it crap and from what i have read its real good for smoking flywheels. so i would recommend to have it replaced with an aftermarket one. mitsu is going 2 avoid warranting and evo as much as possible so i plan 2 just void the damn thing(hks tt installed)
The funny thing is that it has an exedy clutch... If your going to put an exedy from factory please make it a good one... not one that people complain about... Mitsu expect you to void warranty so they don't have to replace anything that goes wrong.
I haven't dealt significantly with Mitsubishi, but this is what I've done with other brands where I thought I could get screwed for warranty work by the time they acknowledge the problem. It's worked out well so far.
There's been a at least a half-dozen of these complaints, too. I wonder if the clutches aren't bedding properly during break-in, causing lots of premature failures.
When you take it in the first time tell them you want it noted in the car's history that you're reporting clutch slippage issues, even if they can't reproduce it. Then when you come in down the road and they can reproduce it, you have some proof that problems have existed for awhile. That way when they pull out the "You've been beating on it for 6000 miles, we're not going to cover it" crap, you can point to the complaint you made at 600 miles.
same thing here. clutch started slipping in first at 4.5k shifted into second and started slipping again at 4.5k, shifted into third same thing.
pulled over and the car stunk of clutch for 1 hour at least. Just happened last week 1,400 miles.it never happened again.
I have never felt something like that before it was weird and embarrassing in traffic.
no way mitsu is going to cover it, its a wear and tear part like your brake pads or windshield wiper blades.... i saw someone blow one out in 150 miles first day they bought it!!! HA HA
sounds like someone launched your car within that first 6 miles. Bring it back you can return the car tell them if they dont fix it you dont want the car no more. They'll fix it real fast
I have an appointment for Thursday morning. I will be in total shock if they tell me its not covered. I plan to make sure I am there if they have a regional rep show up to inspect it.
I can't buy a twin disk clutch, my wife would never forgive me. I already warned her that we might have a problem getting this covered. I purchased this car from South Coast Mitsu and my car looked like it had not been moved in months (it was not detailed for some reason).
Anyway, I'll update you all soon.
Take it to the dealer. I was there today and saw another EVO on the lift with the clutch coming out. Talked to the tech and he said the car had 12k on it and after inspection the throwout bearings went bad. It's being covered under warranty.
Actually getting Mitsubishi to stand by their warranty terms, though, is another matter entirely.
