Sponsored by:
Sponsored by: CARiD
CEL code P0171 System Lean
Old Apr 17, 2009 | 06:06 AM
Noize's Avatar
EvoM Administrator
Originally Posted by Boricua21
Gents I have the same proble first i had the EGR Code P0401 so I checked all the hoses and i had one lose. So i fix them by putting zips on them problem solve. Now i get this code p0171, Im going to check the MAF sensor. But can the Gas make this code to appear if the vehicle was tuned for 91octane and I fill my car with 93 dont know need help and can i still run the car like this or it will cause damage.
The Other question is that my ANTI lock light came up and the code is 82 ST-2 open circuit can someone help me with this before i take the car to the dealer and they rip me off like they normaly do to us evo owners.
EGR?
You're in the wrong forum. You need to start a thread over in the Evo 1-9 sections.
Old Jun 11, 2009 | 12:27 PM
I Phantom I's Avatar
Well I too have this problem now.
After reading up on it, I know what it is and what I need to do. However, I still have a question....
Is it recommended to continue driving the car with this issue (CEL P0171) or should I revert to stock form?
Any help is appreciated, thanks!
Old Jun 15, 2009 | 12:30 PM
skywalker's Avatar
I am not going to tell you what to do or not to do, but I have a question for you.
Did you buy a 30k+ car to "risk" damage when the vehicle is throwing a CEL to warn that something isn't right? I am not trying to be a smartass at all....really I am not but that is what you should ask yourself.
It was risk and reward for me, and the risk wasn't worth it. Would I have been fine to continue running the intake? probably, but it simply wasn't worth it.
Old Jun 22, 2009 | 01:56 PM
Tunerhead's Avatar
Thumbs down Another X with the code: P0171
I recently started to get this code (P0171) too but the weird thing is I'm running stock intake. I had WORKS drop-in filter but reverted back to stock since COBB AP didnt, at the time, have a map for it.
Old Jun 22, 2009 | 02:07 PM
EM@WORKS's Avatar
TunerHead, were you running any tune at the moment of your CEL?
Old Jun 22, 2009 | 03:12 PM
Tunerhead's Avatar
Thanks for the reply.
Yes I am currently running the COBB AP canned stg2 for 91oct (with parts installed required to run map) and this is when the CEL was thrown. Strangely, I've been running this same map for a couple months now same parts, no changes and this CEL just recently started to pop up.
Old Jun 22, 2009 | 03:33 PM
EM@WORKS's Avatar
Has there been any major recent changes in driving style, environment, or major maintenance?
Old Jun 22, 2009 | 04:23 PM
Tunerhead's Avatar
Summer, temps ranging in the 85-100 range with low humidity. Other then that no other changes. I've actually thrown this code in the morning and at night.
Old Feb 14, 2010 | 01:05 PM
Brokenevo's Avatar
Ok so a week after doing my FMIC, and intake swap out I got this code. I was cruising at about 70MPH when the light came on, but it seemed my car was compressor stalling some (too much air) on part throttling. Seems the Forge recirc BOV, wasnt able to move the air enough, as the car would stutter on part throttle like I said. if I use the accel thru cruise it was fine, and if I did moderate throttle it would not create the same surging issue.
I currently have the Perrin FMIC TTR U/LICP and air intake stuff plus shield. I reset the code and did a search to find all this is a common issue, but can we up grade the MAF at all? I seen people going to a AFM system, but is it worth it? Input please!
Old Sep 14, 2010 | 05:26 AM
yorT's Avatar
Same code and found that my vacuum line for the fuel pressure regulator popped off. Time to get a zip tie on that bad boy.
Old Sep 14, 2010 | 11:29 AM
journeymansteve's Avatar
I exchanged emails with David Boshur a few times early into my consideration for tuning and he was kind enough to warn me that ANY aftermarket intake was likely to thrown engine codes, as you're describing. The second post, replying well, said it all and I can only add I can also get that from a dirty MAF sensor from an oiled drop-in filter replacement like the K&N's. You can buy a $4.99 can of MAF cleaner from the parts store for that. IMHO, it's safer to remove the MAF housing and clean the MAF with it in the plastic rather than unbolt the MAF from it's housing. Taking the air filter box off is easy, and the MAF housing is one large hose clamp and a few plastic clips holding the MAF wiring. That way the MAF won't be damaged if you accidentally bump it, or heaven-forbid, drop it, while cleaning.
Old Nov 12, 2010 | 04:28 PM
Bluewind's Avatar
How dangerous is it to run with a P0171 (lean) code for a with a cold air intake for any length of time? Honestly, I want to accumulate more mods before heading down for a tune.
My baseline afr's hovered around 10.25 and peaked at 10.4. Although I'm throwing this code, I have a hard time believing that I'm at a dangerously lean afr.
Old Oct 7, 2011 | 09:45 AM
JeuceJones's Avatar
I just got the same code on my 03 WRX. I took it into the shop for oil. They asked if I wasnted to clean my K&N filter so I let them. As soon as i left the shop I got the PO171 code popping up. Could it be because the guy didnt let the filter dry enough?
HAve you tried cleaning your MAF?
Old Oct 7, 2011 | 11:21 AM
TheBlade's Avatar
I didnt get a chance to read all the responses because I'm at work but.
P0171 is when your fuel trim is adjusting to the max of 15% or more. I used to get this code non-stop on a previous car. It was from a leaking BOV.
So check your vac/press lines and accessories.
Old Oct 10, 2011 | 03:12 PM
It's really too lean, it's likely caused by the MAF being dirty (same "dirty" cycle as the air filter, clean both together.
The MAF, if dirty, will not register the actual amount of air flowing, telling the system that more is needed. That MAF is the really important sensor that does heavy lifting in the real-time "tune" of AF mixture. So when dirty, it lets more air in, causing System Too Lean code. Easy fix, but be careful with the MAF. I leave mine in the intake housing assy after I get the airbox dis-assembled to give it extra protection from accidental droppage.
