Sponsored by:
Sponsored by: CARiD
who has AEM intake and throw a code.
Old May 11, 2009 | 12:20 AM
ak47m203's Avatar
yeah just if anyone experience any cells/code with aem. i search and can't find one. did you use all the tube, i saw others used the stock air flow tube and air inlet tube. t.y
Old May 11, 2009 | 01:16 AM
JoeyM3's Avatar
no problems here. running aem intake with the nisei intake pipe and nisei licp.
Old May 11, 2009 | 06:57 AM
ak47m203's Avatar
but are youtune right for aem... are just wonder if your stock tune!
Old May 11, 2009 | 07:10 AM
malymabl97's Avatar
Is the AEM box the same size as the stock airbox?
Old May 11, 2009 | 07:11 AM
ak47m203's Avatar
no... i think it's bigger.
Old May 11, 2009 | 09:10 AM
5speedx's Avatar
I have the AEM intake installed for about 4 months now and it finally trew a code today... and I thought that the AEM intake is the only intake that would not give you the SES light.. other then that its running perfectly fine.. I guess i'll just reset the ECU and hopefully thats what i'll have to do every 3-4 months...
Old May 11, 2009 | 10:31 AM
JoeyM3's Avatar
i ran a while without a tune with no problems
Old May 11, 2009 | 12:43 PM
EVOXTIMES's Avatar
I'm running a AEM intake and Nisei uicp as well....for about 2 weeks now with no problems.....but will probably get a tune b4 I do have a problem.
Old May 11, 2009 | 01:33 PM
ak47m203's Avatar
so what is your SES light say?
Old May 11, 2009 | 01:47 PM
Hiboost's Avatar
It's likely saying the long term fuel trims are too lean, a tune with a bit of extra fuel added in the offboost part of the load maps should correct an oversize MAF Housing. There may also be a better way of adjusting for the larger MAF at idle and cruise that won't mess up the Open Loop WOT tune. See if you can lookup the code you are getting.
Old May 11, 2009 | 01:51 PM
ak47m203's Avatar
but why sometimes the code will not appear in the first few months or first dynos, maybe by using the same/stock airflowtube/air inlet tube and used only the box/filter with make it safe with stock tune.
Old May 11, 2009 | 04:22 PM
dongchad's Avatar
been running AEM intake for about 4 months now without a tune but there was one incident that my car threw a CEL while i was driving it, but when i was on my way to my friends house to borrow his OBD II scanner, the the CEL went away. by the time i scanned it, found no codes. planning on getting a tune after i get my FMIC ...
Old May 16, 2009 | 04:12 PM
matias04374's Avatar
I threw a code at 1000 miles while smashing like 130 and I ended up with a high idle.I always keep a scan tool in the back of my trunk.I was thinking maybe I threw a code cause I had a mbc,intake,exhaust and no tune.But anyways code never came back after that.I had all those bolt ons at 600 miles.But never floored it till 1000 miles.
Old May 18, 2009 | 11:20 PM
5speedx's Avatar
wow i'm getting back late on this thread.. but the code I threw was P1320 "Ignition timing retard insufficient".. happens to alot of people with intake and no tune.. I am absolutely stock with just the AEM...
Old May 19, 2009 | 12:14 AM
Hassan!'s Avatar
So am i going to be fine with HKS high Power exhaust, Test pipe and AEM air intake + No Tune?
